is there any paper show me the difference?
It is the basics of Reservoir eng.. You have black oil, volatile oil, gas condensate, wet gas and dry gas. If you type google I am not sure you can find condensate oil reservoir, as it doesnt exist to my knowledge. However, when a gas condensate reservoir is producing, a shift of phase enveloppe may occur in part of the reservoir to give a volatile oil. I suggest you read a reservoir engineering book.
Elgharib Basha,
what you say is useful,
are u a petrophysicist or reservoir engineer?
and where are you from?
What are the requirements to transport condensate?
If condensate is a fluid, is it fluid at normal atmospheric pressure and temperature?
Condensate properties listed below:
Molecular Weight (MW): 121.6 Kg/kmol
Specific Gravity (Standard): 0.773
True Vapour Pressure (TVP) @ 100oF: 12psia
Thanks.
