Goodmorning,
i have to design an indirect fired heater to heat a stream of crude oil.
I have sized all the process, what remains is to calculate the thickness of the shell. The API 12K only tell me that i have to design the shell based on Asme VIII div. 1, but it gives me no other inputs.
The shell has these dimensions:
-lenght: 15000 mm
-diameter: 3600 mm
-full of liquid (water/glycol)
-design pressure: atmospheric
-material: carbon steel
How can i calculate the vessel thickness in order to be sure that the vessel will resist to the weight of the water? Is there any formula?
I've tried to use the formula given by ASME regarding pressure vessels, but it gives me a ridocolous thickness (1mm). I think i cannot use this formula to calculate the thickness of an atmospheric thanks
p.s. My boss suggested me to consider a thickness of 12 mm, but i would like to understant WHY he gave me that number...
Thank you
Matteo
