Analytical Troubleshooting of Process Machinery and Pressure Vessels
- Average Rating: 5
- Total Reviews: 1
Book Description:
A highly practical troubleshooting tool for today's complex processing industry
Evolving industrial technology-driven by the need to increase safety while reducing production losses-along with environmental factors and legal concerns has resulted in an increased emphasis on sound troubleshooting techniques and documentation. Analytical Troubleshooting of Process Machinery and Pressure Vessels provides both students and engineering professionals with the tools necessary for understanding and solving equipment problems in today's complex processing environment.
Drawing on forty years of industrial experience in the petrochemical, transportation, and component manufacturing industries, the author introduces analytical models that utilize simple mathematics to provide engineers with the information needed to understand equipment operation and failure modes. This will allow engineering professionals to talk intelligibly with manufacturers, implement modifications required for continued operation, and ultimately help them save millions of dollars in lost production or warranty claims.
Readers will find in-depth coverage of factors that can cause equipment failure, including:
* Component wear and fretting
* Vibration of machines and piping
* Instabilities and sizing of pumps and compressors
* Thermal loads and stresses
* Gear, bearing, shafting, and coupling loading
* Corrosion and materials of construction
By striking a balance between analytical and practical considerations, each potential problem area is illustrated with case studies taken from the author's own extensive experience and accompanied by methods that can be used to address a variety of related challenges.
Download Description:
A highly practical troubleshooting tool for today's complex processing industry Evolving industrial technology-driven by the need to increase safety while reducing production losses-along with environmental factors and legal concerns has resulted in an increased emphasis on sound troubleshooting techniques and documentation. Analytical Troubleshooting of Process Machinery and Pressure Vessels provides both students and engineering professionals with the tools necessary for understanding and solving equipment problems in today's complex processing environment. Drawing on forty years of industrial experience in the petrochemical, transportation, and component manufacturing industries, the author introduces analytical models that utilize simple mathematics to provide engineers with the information needed to understand equipment operation and failure modes. This will allow engineering professionals to talk intelligibly with manufacturers, implement modifications required for continued operation, and ultimately help them save millions of dollars in lost production or warranty claims. Readers will find in-depth coverage of factors that can cause equipment failure, including: Component wear and fretting Vibration of machines and piping Instabilities and sizing of pumps and compressors Thermal loads and stresses Gear, bearing, shafting, and coupling loading Corrosion and materials of construction By striking a balance between analytical and practical considerations, each potential problem area is illustrated with case studies taken from the author's own extensive experience and accompanied by methods that can be used to address a variety of related challenges.
Date: 2007-07-17 Rating: 5
Review:
Mandatory Reading and Reference for Complex Problem Solving
Warning . . . books like this tend to go out of print (OOP). Not since Bob Eisenmann's OOP "Machinery Malfunction Diagnosis and Correction" has anyone put so many practical (dare I say "easy?") calculations in one place that allow the sincere problem solver to do his or her job. What's even better about this book is its seemingly unlimited range of applications. Was the force created by your rotor spinning, alone, enough to loosen those bolts or break that bearing housing? Sofronas helps you understand. Did that collar's interference fit overstress a critical component - enough to cause a failure? Check the book. Think you have water hammer? Prove it fast. Not a compilation of charts and tables - but truly something rare and to be coveted for its ability to arm you with the secrets of extreme failure analysis (lots at risk but little to go by).
or
