Results 1 to 5 of 5
Thread: Flange Leakage qualification for WN ASME Sec VIII Div1 CL 4500 RTJ-ASTM A182 GR F316
  1. Flange Leakage qualification for WN ASME Sec VIII Div1 CL 4500 RTJ-ASTM A182 GR F316
    Dear All,
    I am having one peculiar case, in which we need to qualify flange leakage for our project. In Caesar II software, we dont have any separate template for qualification of flange above 2500#.
    Please throw some light on this topic and we need to provide calculation sheet to client.
    Flange- CL 4500#
    Line Size -10" thk. 38.1 mm
    Design pr. - 273 barg
    Opr. pr. - 217.2 barg
    Design Temp - 330 deg C
    Advance thanks,
    satish
    Re: Flange Leakage qualification for WN ASME Sec VIII Div1 CL 4500 RTJ-ASTM A182 GR F
    Hope by this time you got the appropriate response from some SME. If not, following may be helpful.
    Tightness class for bolted flanged joints with gaskets, are not defined in ASME BPVC or ASME Piping codes. Though, PVRC is working on this subject. EN 13555, EN1591-1 & EN 1591-2 define and specify the tightness classes. EN 13555 provides method for testing the leak rates. Provision in these codes may be helpful to find a solution for your case.
    Please note that tightness classes are specified based on the properties of service fluid, particularly its potential for environment damage or head hazards,
    regards.
  5. Re: Flange Leakage qualification for WN ASME Sec VIII Div1 CL 4500 RTJ-ASTM A182 GR F
    Dear Sir,
    Thanks for your support on throwing light on the subject. I am new to EN13555 code. Can you please provide share any spreadsheet or EN13555 code formula page for preparing spreadsheet.
    Thanks and Regards,
    Satish B
    links:
    EN 13555-2021
    [link Point to another website Only the registered members can access] EN 1591-2-2008
    [link Point to another website Only the registered members can access] EN 1591-1-2013
    all are current editions
  7. Re: Flange Leakage qualification for WN ASME Sec VIII Div1 CL 4500 RTJ-ASTM A182 GR F
    Thank you vey much.
  1. Finally ASME BPVC SECTION VIII-DIV1 2015
    By mohamad3010 in forum Mechanical Engineering
    Last Post: 04-03-2019, 09:39 AM
  2. asme viii div1 appendix 24
    By robydiluca in forum Oil And Gas Production
    Last Post: 05-24-2014, 12:47 PM
  3. Asme esction viii div1 (hinged closure)
    By ravishe in forum Mechanical Engineering
    Last Post: 05-10-2011, 09:49 PM
  4. API 620 vs ASME VIII Div1
    By Jazz79 in forum Mechanical Engineering
    Last Post: 01-28-2010, 12:58 PM
  5. API 620 vs ASME VIII Div1
    Last Post: 11-16-2009, 04:19 PM
