Thank you
Thank you
Dear All, I wan to know about this case:
- In the P vs T profile curve, if the nodal analysis does not intersect between IPR and VPR, the p / T profile does not appear
- When creating a network, you cannot enter a well template created in the well. cannot open in existing well
- how to enter maps on the network, if the file is in the form of .kmz
- on the performance data belonging to Sucker rod pump, the nominal rate is derived from the well rate or pump displacement?
Please give answer Guru
Thanks in advance
Alvaedison
Hi Forum,
Pipesim 2018 full working now with me. Ready to share.
Some other applications like Eclipse 2018, Kappa 5.2, CMG 2018 and ... are also available.
I will be happy if you interested in exchange. follow me on this address:
tnudefski@gmail.com
Regards,
