Thank you again for the files, i copied all the ***** files and now it does not come with the error message however when i tried using RESAP to add soil resistivity values, it did not produce a multilayer soil model.
It is quite possible that i have to learn to run the software, i will be in touch. I am assuming you have been able to use 2K version.
Question for you - You have also shared CDEGS 15.1.4080, does this version also work the same way? or does this one does not have the required ***** files?
Thanks again for your response.
Did you eventually manage to run CDEGS 2K? I know you shared the snapshot of errors you faced while running the software but did it finally work?
