Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 29
Thread: gPROMS(General process modelling system)
  1. gPROMS(General process modelling system)
    does any one know about this software.
    any one has link for this software pls share.
  3. I found gproms 3.15 link but without *****. Somebody can make some ***** or ******** for this version?
    gPROMS 3.15 ---> http:/www.megaupload.com/?d=QWP1Y2BP
    Quote Originally Posted by nipulrgudka View Post
    downloaded but without *****
    If you are installing:
    1. select remote license server(s)
    2. Server1 12345@localhost (You can select a different port, then edit the license file)
    3. Lmtools.exe (as usual)
    !!! Edit Yours_server_name to the name of your computer
    License v.3.15
    SERVER Yours_server_name ANY
    DAEMON PSELMD port=12345
    INCREMENT gPROMS PSELMD 20081111 permanent uncounted \
    VENDOR_STRING=www.lavteam.com HOSTID=ANY \
    ISSUER=Blacksea(smngs) ISSUED=06-feb-2009 TS_OK \
    SIGN=C057A1F25E00
    INCREMENT gMDB PSELMD 20081111 permanent uncounted \
    SIGN=FCF9C1AEB7C2
    INCREMENT gSRV_1 PSELMD 20081111 permanent uncounted \
    SIGN=89821254C056
    INCREMENT gSIM_1 PSELMD 20081111 permanent uncounted \
    SIGN=071780886A56
    INCREMENT gEST_1 PSELMD 20081111 permanent uncounted \
    SIGN=DB80C9549B8A
    INCREMENT gOPT_1 PSELMD 20081111 permanent uncounted \
    SIGN=1A3BEFD8C9CE
    INCREMENT gESO_1 PSELMD 20081111 permanent uncounted \
    SIGN=6D4B3302CC66
    INCREMENT gPROMS_ModelBuilder PSELMD 20081111 permanent uncounted \
    SIGN=5AA788D0A5EA
    INCREMENT gEXD_1 PSELMD 20081111 permanent uncounted \
    SIGN=45CFFD4CF778
    INCREMENT gPROMS_gSERVER_1 PSELMD 20081111 permanent uncounted \
    SIGN=D087F1A8E232
  7. thank you , blacksea
  9. #6
    It works well and thanks blacksea.
  10. Thanks guy for everything. But can anyone explain the ***** procedure properly so that i can be little easy to ***** it.
  11. Thanks, I'm the guy that uploaded gproms 3.15 to megaupload. If i have access to further versions, I will post here.
  12. #9
    Blacksea,
    Thanke you for the license file. I would like to ask where I can find flexlm for this gproms version
    Thanks & Regards,
  13. #10
    The Multiflash v3.7 property package in gPROMS does not work, due to problem with license. If anyone can update license file with license lines for Multiflash., it would be great because use of Gproms is very limited without MF.
  14. #11
    Quote Originally Posted by svmirko View Post
    quite right.
    MF to gproms is vmgthermo to vmgsim
  16. Guys...
    Can you ppl help me out regarding the setup of license..its required for my project
