full list 16.11.2017:
IEC 60404-1:2016 RLV Magnetic materials - Part 1: Classification
IEC 60404-1:2016 Magnetic materials - Part 1: Classification
IEC 60404-1-1:2004 Magnetic materials - Part 1-1: Classification - Surface insulations of electrical steel sheet* strip and laminations
IEC 60404-2:1996+AMD1:2008 CSV Magnetic materials - Part 2: Methods of measurement of the magnetic properties of electrical steel strip and sheet by means of an Epstein frame
IEC 60404-2:1996 Magnetic materials - Part 2: Methods of measurement of the magnetic properties of electrical steel sheet and strip by means of an Epstein frame
IEC 60404-2:1996/AMD1:2008 Amendment 1 - Magnetic materials - Part 2: Methods of measurement of magnetic properties of electrical steel strip and sheet by means of an Epstein frame
IEC 60404-3:1992+AMD1:2002+AMD2:2009 CSV Magnetic materials - Part 3: Methods of measurement of the magnetic properties of electrical steel strip and sheet by means of a single sheet tester
IEC 60404-3:1992+AMD1:2002 CSV Magnetic materials - Part 3: Methods of measurement of the magnetic properties of magnetic sheet and strip by means of a single sheet tester
IEC 60404-3:1992 Magnetic materials - Part 3: Methods of measurement of the magnetic properties of magnetic sheet and strip by means of a single sheet tester
IEC 60404-3:1992/AMD1:2002 Amendment 1 - Magnetic materials - Part 3: Methods of measurement of the magnetic properties of magnetic sheet and strip by means of a single sheet tester
IEC 60404-3:1992/AMD2:2009 Amendment 2 - Magnetic materials - Part 3: Methods of measurement of the magnetic properties of electrical steel strip and sheet by means of a single sheet tester
IEC 60404-3:1992/AMD2:2009/COR1:2009 Corrigendum 1 - Amendment 2 - Magnetic materials - Part 3: Methods of measurement of the magnetic properties of electrical steel strip and sheet by means of a single sheet tester
IEC 60404-4:1995+AMD1:2000+AMD2:2008 CSV Magnetic materials - Part 4: Methods of measurement of d.c. magnetic properties of magnetically soft materials
IEC 60404-4:1995+AMD1:2000 CSV Magnetic materials - Part 4: Methods of measurement of d.c. magnetic properties of magnetically soft materials
IEC 60404-4:1995 Magnetic materials - Part 4: Methods of measurement of d.c. magnetic properties of iron and steel
IEC 60404-4:1995/AMD1:2000 Amendment 1 - Magnetic materials - Part 4: Methods of measurement of d.c. magnetic properties of iron and steel
IEC 60404-4:1995/AMD2:2008 Amendment 2 - Magnetic materials - Part 4: Methods of measurement of d.c. magnetic properties of magnetically soft materials
IEC 60404-5:2015 Magnetic materials - Part 5: Permanent magnet (magnetically hard) materials - Methods of measurement of magnetic properties
IEC 60404-5:2015 RLV Magnetic materials – Part 5: Permanent magnet (magnetically hard) materials – Methods of measurement of magnetic properties
IEC 60404-6:2003 Magnetic materials - Part 6: Methods of measurement of the magnetic properties of magnetically soft metallic and powder materials at frequencies in the range 20 Hz to 200 kHz by the use of ring specimens
IEC 60404-6:2003/COR1:2009 Corrigendum 1 - Magnetic materials - Part 6: Methods of measurement of the magnetic properties of magnetically soft metallic and powder materials at frequencies in the range 20 Hz to 200 kHz by the use of ring specimens
IEC 60404-7:1982 Magnetic materials. Part 7: Method of measurement of the coercivity of magnetic materials in an open magnetic circuit
IEC 60404-8-1:2015 Magnetic materials - Part 8-1: Specifications for individual materials - Magnetically hard materials
IEC 60404-8-3:2005 Magnetic materials - Part 8-3: Specifications for individual materials - Cold-rolled electrical non-alloyed and alloyed steel sheet and strip delivered in the semi-processed state
IEC 60404-8-4:2013 Magnetic materials - Part 8-4: Specifications for individual materials - Cold-rolled non-oriented electrical steel strip and sheet delivered in the fully-processed state
IEC 60404-8-5:1989 Magnetic materials. Part 8: Specifications for individual materials. Section Five: Specification for steel sheet and strip with specified mechanical properties and magnetic permeability
IEC 60404-8-6:2016 Magnetic materials - Part 8-6: Specifications for individual materials - Soft magnetic metallic materials
IEC 60404-8-7:2017 Magnetic materials - Part 8-7: Specifications for individual materials - Cold-rolled grain-oriented electrical steel strip and sheet delivered in the fully processed state
IEC 60404-8-7:2017 RLV Magnetic materials - Part 8-7: Specifications for individual materials - Cold-rolled grain-oriented electrical steel strip and sheet delivered in the fully processed state
IEC 60404-8-8:2017 Magnetic materials - Part 8-8: Specifications for individual materials - Thin electrical steel strip and sheet for use at medium frequencies
IEC 60404-8-9:1994 Magnetic materials - Part 8: Specifications for individual materials - Section 9: Standard specification for sintered soft magnetic materials
IEC 60404-8-10:2009 Magnetic materials - Part 8-10: Specifications for individual materials - Magnetic materials (iron and steel) for use in relays
IEC 60404-9:1987 Magnetic materials. Part 9: Methods of determination of the geometrical characteristics of magnetic steel sheet and strip
IEC 60404-10:2016 RLV Magnetic materials - Part 10: Methods of measurement of magnetic properties of electrical steel strip and sheet at medium frequencies
IEC 60404-10:2016 Magnetic materials - Part 10: Methods of measurement of magnetic properties of electrical steel strip and sheet at medium frequencies
IEC 60404-11:1991+AMD1:1998+AMD2:2012 CSV Magnetic materials - Part 11: Method of test for the determination of surface insulation resistance of magnetic sheet and strip
IEC 60404-11:1991+AMD1:1998 CSV Magnetic materials - Part 11: Method of test for the determination of surface insulation resistance of magnetic sheet and strip
IEC 60404-11:1991 Magnetic materials - Part 11: Method of test for the determination of surface insulation resistance of magnetic sheet and strip
IEC 60404-11:1991/AMD1:1998 Amendment 1 - Magnetic materials - Part 11: Method of test for the determination of surface insulation resistance of magnetic sheet and strip
IEC 60404-11:1991/AMD2:2012 Amendment 2 - Magnetic materials - Part 11: Method of test for the determination of surface insulation resistance of magnetic sheet and strip
IEC 60404-12:1992 Magnetic materials - Part 12: Guide to methods of assessment of temperature capability of interlaminar insulation coatings
IEC 60404-13:1995 Magnetic materials - Part 13: Methods of measurement of density* resistivity and stacking factor of electrical steel sheet and strip
IEC 60404-14:2002 Magnetic materials - Part 14: Methods of measurement of the magnetic dipole moment of a ferromagnetic material specimen by the withdrawal or rotation method
IEC 60404-15:2012+AMD1:2016 CSV Magnetic materials - Part 15: Methods for the determination of the relative magnetic permeability of feebly magnetic materials
IEC 60404-15:2012 Magnetic materials - Part 15: Methods for the determination of the relative magnetic permeability of feebly magnetic materials
IEC 60404-15:2012/AMD1:2016 Amendment 1 - Magnetic materials - Part 15: Methods for the determination of the relative magnetic permeability of feebly magnetic materials
IEC TR 61807:1999 Magnetic properties of magnetically hard materials at elevated temperatures - Methods of measurement
IEC TR 62331:2005 Pulsed field magnetometry
IEC TR 62383:2006 Determination of magnetic loss under magnetic polarization waveforms including higher harmonic components - Measurement* modelling and calculation methods
IEC TR 62517:2009 Magnetizing behaviour of permanent magnets
IEC TR 62518:2009 Rare earth sintered magnets - Stability of the magnetic properties at elevated temperatures
IEC TR 62581:2010 Electrical steel - Methods of measurement of the magnetostriction characteristics by means of single sheet and Epstein test specimens
IEC TR 62797:2013 International comparison of measurements of the magnetic moment using vibrating sample magnetometers (VSM) and superconducting quantum interference device (SQUID) magnetometers
IEC TR 62981:2017 Studies and comparisons of magnetic measurements on grain-oriented electrical steelsheet determined by the single sheet test method and Epstein test method
the missing:
