Quote Originally Posted by himmelstern View Post
I finally can make RUN or work the SES CDEGS 2k* some files were missing and found at 4shared.
the software works fine* but some example files are missing too.
For me the software 2k its ok* for me* because with it can make some things that with etap 16 or cymgrd can't do* and I have to use ATPdraw or EMTP and matlab to acomplish it.
in this case even the software is old* the calculations are almost the same. It's something like work with etap 4 and etap 17 to do a load flow calculation. ETAP 4 do load flow and etap 16.1 and etap 17 do it too.
Its the case to do an spreadsheet with excel 2000 and Excel 2016* autosum function it's the same.
I use cymcap and cymgrd for winxp using virtual machine* because I don't have lastest versions. the only thing its for to grounding grids with IEEE 80-2013 with cymgrd* can't* only use IEEE 80-2000 version. but I can get some information that etap needs to be calculated with etap that don't do it* I have to use cymgrd later etap to acomplish that model. with etap the model is using IEEE 80 2013.
I will beguin to learn to use this software.
Could you share the missing file you found at 4shared? Thanks
