full list:
IEC 60313:2002 Coaxial connectors used in nuclear laboratory instrumentation
IEC 60412:2014 Nuclear instrumentation - Nomenclature (identification) of scintillators and scintillation detectors and standard dimensions of scintillators
IEC 60462:2010 Nuclear instrumentation - Photomultiplier tubes for scintillation counting - Test procedures
IEC 60498:1975 High-voltage coaxial connectors used in nuclear instrumentation
IEC 60600:1979 Equipment for minehead assay and sorting radioactive ores in containers
IEC 60677:1980 Block transfers in CAMAC systems
IEC 60692:1999 Nuclear instrumentation - Density gauges utilizing ionizing radiation - Definitions and test methods
IEC 60713:1981 Subroutines for CAMAC
IEC 60729:1982 Multiple controllers in a CAMAC crate
IEC 60759:1983 Standard test procedures for semiconductor X-ray energy spectrometers
IEC 60759:1983/AMD1:1991 Amendment 1 - Standard test procedures for semiconductor X-ray energy spectrometers
IEC 60775:1983 Real-time BASIC for CAMAC
IEC 60912:1996 Nuclear instrumentation - ECL (emitter coupled logic) front panel interconnections in counter logic
IEC 60935:1996 Nuclear instrumentation - Modular high speed data acquisition system- FASTBUS
IEC 60973:1989 Test procedures for germanium gamma-ray detectors
IEC 60982:1989 Level measuring systems utilizing ionizing radiation with continuous or switching output
IEC 61052:1991 IEC 1052 FASTBUS standard routines. Standard routines for use with FASTBUS data acquisition system
IEC 61145:1992 Calibration and usage of ionization chamber systems for assay of radionuclides
IEC 61239:1993 Nuclear instrumentation - Portable gamma radiation meters and spectrometers used for prospecting - Definitions* requirements and calibration
IEC 61301:1994 Nuclear instrumentation - Digital bus for NIM instruments
IEC 61304:1994 Nuclear instrumentation - Liquid-scintillation counting systems - Performance verification
IEC 61335:1997 Nuclear instrumentation - Bore-hole apparatus for X-ray fluorescence analysis
IEC 61336:1996 Nuclear instrumentation - Thickness measurement systems utilizingionizing radiation - Definitions and test methods
IEC 61435:2013 Nuclear instrumentation - High-purity germanium crystals for radiation detectors - Measurement methods of basic characteristics
IEC 61452:1995 Nuclear instrumentation - Measurement of gamma-ray emission rates of radionuclides - Calibration and use of germanium spectrometers
IEC 61453:2007 Nuclear instrumentation - Scintillation gamma ray detector systems for the assay of radionuclides - Calibration and routine tests
IEC 61874:1998 Nuclear instrumentation - Geophysical borehole instrumentation to determine rock density ('density logging')
IEC 61976:2000 Nuclear instrumentation - Spectrometry - Characterization of the spectrum background in HPGe gamma-ray spectrometry
IEC 62088:2001 Nuclear instrumentation - Photodiodes for scintillation detectors - Test procedures
IEC 62089:2001 Nuclear instrumentation - Calibration and usage of alpha/beta gas proportional counters
IEC 62372:2006 Nuclear instrumentation - Housed scintillators - Measurement methods of light output and intrinsic resolution
IEC 62495:2011 Nuclear instrumentation - Portable X-ray fluorescence analysis equipment utilizing a miniature X-ray tube
IEC 62598:2011 Nuclear instrumentation - Constructional requirements and classification of radiometric gauges
IEC 62976:2017 Industrial non-destructive testing equipment - Electron linear accelerator
the missing is:
