Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 25 to 36 of 59
Thread: Cymcap 7.0
  1. #25
    Re: Cymcap 7.0
    give more details on your specific installation. how many circuits/conductors/type/voltage and so on... maybe upload your data someplace
    cymcap can do for sure the ampacity in tunnel part as for the other one never went that far... maybe cdegs multilines
  3. Re: Cymcap 7.0
    Cable construction: 1*800 63 kv
    both end bonding
    double circuit with flat formation and the cables are touched together on cable tray
    I success to calculate current carrying ampacity but i can`t calculate induced current and voltage on sheath.
  5. Re: Cymcap 7.0
    do cyme_tcc software require another software to install ? i got the software from my college teacher and it's cannot be installed . There is 1 error code appear when i try to install it . ErrorCode 14 * 5270.577 .
    And what's about protection key utilities ? Sorry i really knew this software after my college teacher give the task to me . thanks for the help
  6. #28
    Quote Originally Posted by cyclops945 View Post
    Please create another thread for this topic.
    Sent from my GT-I9082 using Tapatalk
  7. #29
    Re: Cymcap 7.0
  9. #30
    Re: Cymcap 7.0
    you can calculate induced sheath voltage and circulating current with Digsilent. I upload documentation and example in:
  10. Re: Cymcap 7.0
    thanks a lot dear user lobo624 and ionioni
    I downloaded the documents
    I should find and download PowerFactory and then run this items.I will do them.
    after that i report u my results.
  11. #32
    Cymcap 7.0
    Ctmcap calculates temperature in every component and voltage and current in metallic componenets at reports.
    Cymcap is a very complete software for me is better than etap module. I don't used recent versions of cymcap but cymcap can't calculate cables together in the same raceway. One cable per pipe. Etap can.
    Cymcap uses iec 60287 and etap ieee 835. The method of iec is better because use the method of ieee and improve it as a basis. Ieee method is for year 1985 And past years. Iec is bases on 1985 techniques and improve it to year 2003.
    Any one has the lastest versions of Cymcap with medds
  12. #33
    Re: Cymcap 7.0
    Quote Originally Posted by moduqa View Post
    v7.0 is fake too. ( go ahead* prove me wrong )
  13. #34
    Re: Cymcap 7.0
  14. Re: Cymcap 7.0
    Quote Originally Posted by lobo624 View Post
    Can u share Cable Tutorial 2.pfd or say where is it?
  16. #36
    Re: Cymcap 7.0
    Quote Originally Posted by ionioni View Post
    Excellent ....
