Error message "The specified account already exist". Installation halted. How to overcome this?
I think you forgot about the Internet connection. All connections must be disabled before you start to install OM.
I think now you need to clean your registry after the failed installation. Use one of reg cleaners (or manually - longer, but better). After you've deleted all OM paths and keys from your PC you may try to install it again. And also note that this soft can be updated up to 8.4.2 only because the greedy Ge*soft revoked the "license"( which you will install) starting from OM 8.5.
Installation should be a little bit different on the various Wins (7,8,10 - may be you'll need to use command prompt to launch ***.exe) - it depends on the security policy applying in your company or your PC security settings.
Also you'd better know that some antiviruses mark ***.exe as a virus, so you've to disable your antivirus software.
Hi.
I'm wondering if people still has the link for oasis montaj? I want to apply job for UXO detection and want to familiarize myself with the software.
