Is it possible to design shell and tube heat exchanger in HYSYS? If Possible please help me.
Hi
Hysys just is not possible.
You must have Aspen Exchanger Design & Rating (EDR) installed.
With this application, you can design and revise a heat exchanger
hi
hysys, for sure, is not capable of designing a heat exchanger, but it can help you certainly when you have an already designed exchanger and you wish to see that actual exchanger geometry result on simulation i.e. pressure drop.
as camiqmex pointed, Aspen EDR is good to start with. But HTRI is used industrially for designing/rating heat exchangers of all type.
What these software's do? they just reduce the time of calculation. You just need to mix your knowledge with software input and you will have your results.
Ammad Khan
I require me-di-ci-ne for
Name: AspenTech Aspen Exchanger Design & Rating
Version: 7.3 (25.0.0.2677)
Read more:[link Point to another website Only the registered members can access]
plz help.
you just need to read the manuals for the software.
use knowledge of your studies
Use your brain
