Reservoir is gas bearing carbonates, density log reads very low in gas interval which gives high porosity (not sure whether gas correction was applied or not). NMR is also taken, gives porosity which is significantly less than density log derived porosity in the same gas bearing zone. No core taken therefore no core porosity for calibration. Question is which porosity should one trust the more, density log derived porosity or NMR porosity? Thank you.
