updated with one EN version of standard
updated with 3 valid editions of EN 764 - thanks to 66GeePee
full list:
EN 286-1:1998 Simple unfired pressure vessels designed to contain air or nitrogen - Part 1: Pressure vessels for general purposes
EN 286-1:1998/AC:2002 Simple unfired pressure vessels designed to contain air or nitrogen - Part 1: Pressure vessels for general purposes
EN 286-1:1998/A1:2002 Simple unfired pressure vessels designed to contain air or nitrogen - Part 1: Pressure vessels for general purposes
EN 286-1:1998/A2:2005 Simple unfired pressure vessels designed to contain air or nitrogen - Part 1: Pressure vessels for general purposes
EN 286-2:1992 Simple unfired pressure vessels designed to contain air or nitrogen - Part 2: Pressure vessels for air braking and auxiliary systems for motor vehicles and their trailers
EN 286-2:1992/AC:1992 Simple unfired pressure vessels designed to contain air or nitrogen - Part 2: Pressure vessels for air braking and auxiliary systems for motor vehicles and their trailers
EN 286-3:1994 Simple unfired pressure vessels designed to contain air or nitrogen - Part 3: Steel pressure vessels designed for air braking equipment and auxiliary pneumatic equipment for railway rolling stock
EN 286-4:1994 Simple unfired pressure vessels designed to contain air or nitrogen - Part 4: Aluminium alloy pressure vessels designed for air braking equipment and auxiliary pneumatic equipment for railway rolling stock
EN 764-1:2015 Pressure equipment - Part 1: Vocabulary
EN 764-2:2012 Pressure equipment - Part 2: Quantities, symbols and units
EN 764-3:2002 Pressure equipment - Part 3: Definition of parties involved
EN 764-4:2014 Pressure equipment - Part 4: Establishment of technical delivery conditions for metallic materials
EN 764-5:2014 Pressure Equipment - Part 5: Compliance and Inspection Documentation of Materials
CEN/TR 764-6:2012 Pressure equipment - Part 6: Structure and content of operating instructions
EN 764-7:2002 Pressure equipment - Part 7: Safety systems for unfired pressure equipment
EN 764-7:2002/AC:2006 Pressure equipment - Part 7: Safety systems for unfired pressure equipment
EN 13445-1:2014 Unfired pressure vessels - Part 1: General
EN 13445-1:2014/A1:2014 Unfired pressure vessels - Part 1: General
EN 13445-2:2014 Unfired pressure vessels - Part 2: Materials
EN 13445-3:2014 Unfired pressure vessels - Part 3: Design
EN 13445-3:2014/ A1:2015 Unfired pressure vessels - Part 3: Design
EN 13445-4:2014 Unfired pressure vessels - Part 4: Fabrication
EN 13445-5:2014 Unfired pressure vessels - Part 5: Inspection and testing
EN 13445-6:2014 Unfired pressure vessels - Part 6: Requirements for the design and fabrication of pressure vessels and pressure parts constructed from spheroidal graphite cast iron
EN 13445-6:2014 / A1:2015 Unfired pressure vessels - Part 6: Requirements for the design and fabrication of pressure vessels and pressure parts constructed from spheroidal graphite cast iron
CR 13445-7:2002 Unfired pressure vessels - Part 7: Guidance on the use of the conformity procedures
EN 13445-8:2014 Unfired pressure vessels - Part 8: Additional requirements for pressure vessels of aluminium and aluminium alloys
EN 13445-8:2014/A1:2014 Unfired pressure vessels - Part 8: Additional requirements for pressure vessels of aluminium and aluminium alloys
CEN/TR 13445-9:2011 Unfired pressure vessels - Part 9: Conformance of the EN 13445 series to ISO 16528
EN 13445-10:2015 Unfired pressure vessels - Part 10: Additional requirements for pressure vessels of nickel and nickel alloys
CEN/TR 13445-101:2015 Unfired pressure vessels - Example of application
CEN/TR 13445-102:2015 Unfired pressure vessels - Part 102: Example of application of vertical vessel with bracket supports
EN 13831:2007 Closed expansion vessels with built in diaphragm for installation in water
EN 14359:2006+A1:2010 Gas-loaded accumulators for fluid power applications
EN 15776:2011 Unfired pressure vessels - Requirements for the design and fabrication of pressure vessels and pressure parts constructed from cast iron with an elongation after fracture equal or less than 15 %
EN 15776:2011/ A1:2015 Unfired pressure vessels - Requirements for the design and fabrication of pressure vessels and pressure parts constructed from cast iron with an elongation after fracture equal or less than 15 %
missing AMD's:
EN 13445-3:2014/ A1:2015 Unfired pressure vessels - Part 3: Design - missing A1:2015
EN 13445-6:2014 / A1:2015 Unfired pressure vessels - Part 6: Requirements for the design and fabrication of pressure vessels and pressure parts constructed from spheroidal graphite cast iron - missing A1:2015
EN 15776:2011/ A1:2015 Unfired pressure vessels - Requirements for the design and fabrication of pressure vessels and pressure parts constructed from cast iron with an elongation after fracture equal or less than 15 % - missing A1:2015
missing standards:
new links:
or
