Results 1 to 8 of 8
Thread: CEN Standards Collection 137/370: CEN TC 130-Space Heating Appliances Without Integra
    complete
    EN 215:2004 Thermostatic radiator valves - Requirements and test methods
    EN 215:2004/A1:2006 Thermostatic radiator valves - Requirements and test methods
    EN 442-1:2014 Radiators and convectors - Part 1: Technical specifications and requirements
    EN 442-2:2014 Radiators and convectors - Part 2: Test methods and rating
    EN 1264-1:2011 Water based surface embedded heating and cooling systems - Part 1: Definitions and symbols
    EN 1264-2:2008+A1:2012 Water based surface embedded heating and cooling systems - Part 2: Floor heating: Prove methods for the determination of the thermal output using calculation and test methods
    EN 1264-3:2009 Water based surface embedded heating and cooling systems - Part 3: Dimensioning
    EN 1264-4:2009 Water based surface embedded heating and cooling systems - Part 4: Installation
    EN 1264-5:2008 Water based surface embedded heating and cooling systems - Part 5: Heating and cooling surfaces embedded in floors, ceilings and walls - Determination of the thermal output
    EN 14037-1:2003 Ceiling mounted radiant panels supplied with water at temperature below 120 °C - Part 1: Technical specifications and requirements
    EN 14037-2:2003 Ceiling mounted radiant panels supplied with water at temperature below 120 °C - Part 2: Test method for thermal output
    EN 14037-3:2003 Ceiling mounted radiant panels supplied with water at temperature below 120 °C - Part 3: Rating method and evaluation of radiant thermal output
    EN 16313:2013 Connections for heating and cooling appliances - Detachable connection with outside threaded pipe G ¾ A and inside cone
    EN 16430-1:2014 Fan assisted radiators, convectors and trench convectors - Part 1: Technical specifications and requirements
    EN 16430-2:2014 Fan assisted radiators, convectors and trench convectors - Part 2: Test method and rating for thermal output
    EN 16430-3:2014 Fan assisted radiators, convectors and trench convectors - Part 3: Test method and rating for cooling capacity
    [link Point to another website Only the registered members can access] or
    Re: CEN standards collection 137/100: CEN TC 130-Space Heating Appliances Without Int
    Re: CEN Standards Collection 137/300: CEN TC 130-Space Heating Appliances Without Int
    fresh links:
    or
    Re: CEN Standards Collection 137/340: CEN TC 130-Space Heating Appliances Without Int
    Everything same
  7. #5
    refreshed links:
    or
  9. #6
    Re: CEN Standards Collection 137/370: CEN TC 130-Space Heating Appliances Without Int
    update:
    added some new editions and some new standards:
    EN 14037-1:2016 Free hanging heating and cooling surfaces for water with a temperature below 120°C - Part 1: Pre-fabricated ceiling mounted radiant panels for space heating - Technical specifications and requirement
    EN 14037-2:2016 Free hanging heating and cooling surfaces for water with a temperature below 120°C - Part 2: Pre-fabricated ceiling mounted radiant panels for space heating - Test method for thermal output
    EN 14037-3:2016 Free hanging heating and cooling surfaces for water with a temperature below 120°C - Part 3: Prefabricated ceiling mounted radiant panels for space heating - Rating method and evaluation of radiant thermal output
    EN 14037-4:2016 Free hanging heating and cooling surfaces for water with a temperature below 120°C - Part 4: Pre-fabricated ceiling mounted radiant panels - Test method for cooling capacity
    EN 14037-5:2016 Free hanging heating and cooling surfaces for water with a temperature below 120°C - Part 5: Open or closed heated ceiling surfaces - Test method for thermal output
    sector complete
    link:
  10. #7
    nothing changed
  11. #8
    update:
    EN versions or better quality:
    EN 1264-5:2008 Water based surface embedded heating and cooling systems - Part 5: Heating and cooling surfaces embedded in floors* ceilings and walls - Determination of the thermal output
  1. CEN Standards Collection 241/370: CEN TC 163-Sanitary Appliances
    Last Post: 07-01-2017, 05:45 AM
  2. Replies: 5
    Last Post: 06-28-2017, 06:36 AM
  3. Replies: 6
    Last Post: 05-30-2017, 05:09 AM
  4. CEN Standards Collection 165/370-CEN TC 49-Gas Cooking Appliances
    Last Post: 05-30-2017, 01:07 AM
  5. Replies: 9
    Last Post: 05-30-2017, 12:56 AM
