regards
I'm new to using software PIPESIM . I'm trying to run the example that is in the user guide example is that of Oil Well Performance Analysis Case Study page 262. everything was fine until I try to do the Matching Flow Correlations . when introducing the data of pressure and depth (Select Data " Load / Add Measured Data. ) aperce me the following error:" the number of query values ​​and the number of target fields are different. " then not let me save the data pressure vs depth. If they are so kind to help me solve the problem.
