Hi
Anybody willing to share ISO 9099 & ISO 8864.
Thank you very much
Hi
Thank you very much
Hi all,
I need IEEE 43-2013. Please send it on vania.spasova@gmail.com. Thanks in advance.
Hi All,
Does any one have the following standards:
1- ISO 9905 Technical specifications for centrifugal pumps -- Class I
2- ISO 9908 Technical specifications for centrifugal pumps -- Class III / Amd 2011
3- EN 733 End-suction centrifugal pumps, rating with 10 bar with bearing bracket. Nominal duty point, main dimensions, designation system
4- ISO 9906:2012 Rotodynamic pumps -- Hydraulic performance acceptance tests -- Grades 1, 2 and 3
My e-mail: wael_youssef@hotmail.com
Thanx & Regards
Thank you
Hi DORIO,
I would like them very much. Pls send me via email: hstanley87@yahoo.com
Thanks in advance.
Hello Everyone
Anybody willing to share API RP 42? Please send via mail: kazynski2@gmail.com Thanks in advance.
dear Dorio, if you have AGA report no 11, please kindly send to adityano@gmail.com
thank you
i have api,asme,iec,ieee,bsi and more access, if need free pm me.
Copy to planktonward@gmail.com please![]()
Can you Give me the following latest codes
BS EN ISO 15609-1 –for WPS preparation
BS EN ISO 15614-1:2004+A2 : 2012 : Welding Procedure test for Arc welding of steel
BS EN ISO 287-1:2011 & BS EN ISO 9601-1:2013
NSSS 5 th Edition
BS 1011-1&2– Metal Arc welding of carbon and carbon manganese steel
BSEN 2560 / 17632 / 14171 (639/ 756 /758) – Wire Electrode & Wire flux
BS EN 17640 & 11666 / 23279 reference method & Acceptation for ultrasonic testing of welds
BS EN 17638 & 23278 - Method & Acceptation for MPI of welds
BS EN 571-1 / 23277– Method & Acceptation for DPI of welds
BS 5493 / 2063 – Code of Practice Protective coating for Steel Structures
BS 1461 / BS 729 -Hot dip galvanized coating on steel
BS 4652 – Repair method for zinc rich primer
BS EN 2063 – Metallic and other inorganic coatings.
BS EN ISO 8501 -1 and 8503-2 & 3 – Preparation of steel substrates before application of paints and related products
BS EN ISO 12944-Part 4 –
BS EN ISO 12944-Part 5 –
BS EN ISO 12944-Part 7 –General guidelines of coating inspection.
BS EN 3900 –Part C5 & BS EN 2808 – Coating film thickness measurement method.
BS EN 3900- Part E6 & BS EN 2409 – Painting Adhesion test
SB EN ISO 2063 –Section 8 – Fame –sprayed Zinc test
BS 4 – Structural Steel sections – Part 1
BS 5950 Part 1 & 2 – Structural Steel work in Building
AGA Report No. 11 Revised
Hi. Have you ever find this ISO 13579. Could you please share with me. Thanks jpl860@gmail.com
Best regards
