Page 1 of 3 1 2 3 LastLast
Results 1 to 12 of 28
Thread: Asme 2013
    Asme 2013
    ├ASME B16.1-2010_Gray Iron Pipe Flanges and Flanged Fittings Classes 25, 125, and 250
    ├ASME B16.11-2011_Forged Fittings, Socket-Welding and Threaded
    ├ASME B16.12-2009_Cast Iron Threaded Drainage Fittings
    ├ASME B16.15-2011_Cast Copper Alloy Threaded Fittings Classes 125 and 250
    ├ASME B16.18-2012_Cast Copper Alloy Solder Joint Pressure Fittings
    ├ASME B16.20-2012_Metallic Gaskets for Pipe Flanges Ring-Joint, Spiral-Wound and Jacketed
    ├ASME B16.21-2011_Nonmetallic Flat Gaskets for Pipe Flanges
    ├ASME B16.22-2012_Wrought Copper and Copper Alloy Solder-Joint Pressure Fittings_not latest
    ├ASME B16.25-2012_Buttwelding Ends
    ├ASME B16.34-2013_Valves Flanged, Threaded and Welding End
    ├ASME B16.48-2010_Line Blanks
    ├ASME B16.5-2013_Pipe Flanges and Flanged Fittings
    ├ASME B16.9-2012_Factory Made Wrought Buttwelding Fittings
    ├ASME B30.20-2003 Below the hook Lifting Devices
    ├ASME B31.1 2012_Power Piping
    ├ASME B31.3_2012_Process Piping
    ├ASME B31.4 2012_Pipeline Transportation Systems for Liquid and Slurries
    ├ASME B31.5-2013_Refrigeration Piping and Heat Transfer Components
    ├ASME B31.8-2012_Gas Transmission and Distribution Piping Systems
    ├ASME BPE-2012_Bioprocessing Equipment
    ├ASME BPVC Code Cases-2013_Boilers and Pressure Vessels
    ├ASME BPVC Section I-2013_Rules for Construction of Power Boilers
    ├ASME BPVC Section II-2013_Materials-Part A-Ferrous Materials Specifications (Vol 1 of 2)
    ├ASME BPVC Section II-2013_Materials-Part A-Ferrous Materials Specifications (Vol 2 of 2)
    ├ASME BPVC Section II-2013_Materials-Part B-Nonferrous Material Specifications
    ├ASME BPVC Section II-2013_Materials-Part C-Specifications for Welding Rods Electrodes and Filler Metals
    ├ASME BPVC Section II-2013_Materials-Part D-Properties-(Metric)
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Division 1-Subsection NB-Class 1 Components
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Division 1-Subsection NC-Class 2 Component
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Division 1-Subsection ND-Class 3 Components
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Division 2-Code for Concrete Containments
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Divison 3-Containments for Transportation & Storage of Spent Nuclear Fuel & High Level Radioactive M
    ├ASME BPVC Section III-2013_Rules for Construction of Nuclear Facility Components-Divison 3-Containments for Transportation & Storage of Spent Nuclear Fuel & High Level Radioactive Material & Waste
    ├ASME BPVC Section III-2013_Rules for Constructions of Nuclear Facility Components-Subsection NCA-General Requirements for Division 1 and Division 2
    ├ASME BPVC Section IV-2013_Rules for Construction of Heating Boilers
    ├ASME BPVC Section IX-2013_Welding, Brazing, and Fusing Qualifications
    ├ASME BPVC Section V-2013_Nondestructive Examination
    ├ASME BPVC Section VI-2013_Recommended Rules for the Care and Operation of Heating Boilers
    ├ASME BPVC Section VII-2013_Recommended Guidelines for the Care of Power Boilers
    ├ASME BPVC Section VIII-2013_Rules for Construction of Pressure Vessels-Division 1
    ├ASME BPVC Section VIII-2013_Rules for Construction of Pressure Vessels-Division 2-Alternative Rules
    ├ASME BPVC Section VIII-2013_Rules for Construction of Pressure Vessels-Division 3-Alternative Rules for Construction of High Pressure Vessels
    ├ASME BPVC Section X-2013_Fiber-Reinforced Plastic Pressure Vessels-new
    ├ASME BPVC Section X-2013_Fiber-Reinforced Plastic Pressure Vessels-old
    ├ASME BPVC Section XII-2013_Rules for Construction and Continued Service of Transport Tanks
    ├ASME BTH-1-2008-Design-of-Below-the-Hook-Devices
    ├ASME BTH-1–2005
    ├ASME PTB-3-2013_Section VIII-Division 2 Example Problem Manual
    ├ASME PTB-4-2013_Section VIII-Division 1 Example Problem Manual
    ├ASME PTB-5-2013_Section VIII-Division 3 Example Problem Manual
    └ASME PTB-6-2013_Guidelines for Strain Gaging of Pressure Vessels Subjected to External Pressure Loading in the PVHO-1 Standard
    Link Download:
    Advertising world
  3. Re: Asme 2013
    Re: Asme 2013
    thank you
    Re: Asme 2013
    Thanks very much for exselent post
  7. #5
    Re: Asme 2013
    Great collection you have there.... Thanks a lot.
  9. Re: Asme 2013
    Thanks dude.
    I appriciate a lot.
  10. Re: Asme 2013
    Thanks dude.
    I appriciate a lot.
  11. Re: Asme 2013
    thank u
  12. Re: Asme 2013
    Thanks a lot Bro.....!!!! Really awesome....!!!
  13. Re: Asme 2013
    Thank you!
  14. Re: Asme 2013
    Thank you!
  16. #12
    Re: Asme 2013
    Thanks a lot!
  1. Difference between ASME IX 2013 and ASME IX 2010 Add.2011
    By yakkidudu in forum Oil And Gas Production
    Last Post: 07-14-2026, 02:50 PM
  2. ASME PTB-3-2013 asme section viii div.2 ,example problem manual
    By lois in forum Mechanical Engineering
    Last Post: 02-25-2025, 01:20 PM
  3. Asme 16.35 2013
    By Lep in forum Mechanical Engineering
    Last Post: 11-25-2024, 05:34 PM
  4. Asme sec.ix 2013
    By laxman2341 in forum Pipeline And Fluid Flow
    Last Post: 04-29-2014, 07:04 AM
  5. Asme b16.34 2013
    By gendutgede in forum Mechanical Engineering
    Last Post: 10-25-2013, 04:34 AM
