Results 1 to 7 of 7
Thread: Number of stifferner ring in tower
  1. Number of stifferner ring in tower
    Dear all expert,
    Please help me how to determine the number of stiffener ring in tower.
    if DP is 4. kg/cm2
    DT is 160 C
    Full Vacuum
    2400mm ID
    30,000 TL
    SA516-70
    Compress automatically calculating thickness of shell considering the external pressure.
    Compress not recommending how many stiffener ring required to reduce thickness.
    Please help me to determined how many stiffener ring required.
    Thanks in advance
    Axeus
    Hello, i sm not familiar with compress, but this is what i do in pvelite: i place one stiffener ring at or near the middle of each shell course. In your case, having a 30 meters shell, i imagine you split it in at least 12 courses each 2.5 meters, so it will be like 12 stiffening rings. Hope this helps.
    Sent from my ALCATEL ONE TOUCH 7041X using Tapatalk
  4. Re: Number of stifferner ring in tower
    Quote Originally Posted by gerge22 View Post
    Thanks,
    How do you calculate the stiffener size?
  5. Re: Number of stifferner ring in tower
    Thanks,
    actually i don't calculate them , pvelite does.
  8. Re: Number of stifferner ring in tower
    for stiffener rings, in my experience you should first find the most economical way, either using the same thickness as shell of finding structural steel that meet the required material.
    Compress will automatically suggest the stiffener size if it doesn't meet the total inertia required.
  9. Re: Number of stifferner ring in tower
  1. Ring Out PDC Drilling bit...
    By dejavuoil in forum Drilling And Workover
    Last Post: 09-02-2013, 03:25 PM
  2. Ring spacer
    By ilyes13 in forum Pipeline And Fluid Flow
    Last Post: 12-01-2011, 11:40 AM
