Results 1 to 11 of 11
Thread: Tight Gas Reservoir Simulation
  1. Tight Gas Reservoir Simulation
    Can anybody share Eclipse data files or Petrel model with multi stage frac horizontal Well and/or vertical/deviated comingled well.
    Right now I am working on it. Will post in some days
    206pet22@student.uet.edu.pk
    Bilal Amjad
    Independent Oil & Gas Consultant
    A Geological and Petroleum Engineering Information Resource and Consultancy
    following
    following too
  7. #5
    Sample Case
    ECLIPSE TGR Case with a Horizontal Well and 3 Fracs
    Reservoir Information
    Permeability = 0.01 mD
    Porosity = 0.02
    Reservoir Thickness = 175 ft.
    Gas Initially in Place = 1.411 BCF
    Swc = 0.20
    Class = volumetric
    Gas Composition = 95% C1 + 5% C2
    Grids (Nx, Ny, Nz) = 100 x 120 x 5
    Grid Size = 400 x 400 x 35
    Fracture Information
    Half Length ( ) = 200 ft. (includes well radius)
    Width ( ) = 0.2 ft.
    Porosity ( ) = 0.5
    Permeability ( ) = 100 D
    Fracture Mutual Spacing = 7600 ft.
    File
    Bilal Amjad
  9. Thanks Bilal
  10. #7
    Remember to comment on it.
    Bilal Amjad
  11. Hello Bilal,
    You have indicated that the horizontal well has 3 hydraulic fracture, can you explain that. The 0.2 ft LGR which has a permeability of 100000 mD has 40 grid cells, which I think representing 40 fractures. I am assuming that you are using Excel for defining LGR grids and properties. The higher frac conductivity has made it close to infinite cond fracture, which can be reduced to lower the gas rate from the wells. I am not sure for how long the linear flow continued, but the initial rates of about 100 MMscfd lasted for about 400 days, which is whey too high, what we observe in the field.
    rasha
  12. Quote Originally Posted by rashagreat View Post
    Hello Bilal,
    rasha
    Bilal's model has 40 stages of frac instead of 3. Also, the fracture height is 35 ft (didn't mention it in the description). Otherwise, all the data looks fine to me. Rasha, you'll have to use your own reservoir properties to match the observed rates.
    mh_1809
  13. #10
    I am following too!!!!
  14. Re: Tight Gas Reservoir Simulation
    The sample is really useful!!!
    Thanks for sharing...
  1. Help Needed DST in tight gas reservoir
    By abdulasad in forum Reservoir
    Last Post: 06-08-2012, 05:34 PM
  2. Tight gas Reservoir
    By MIROINE in forum Reservoir
    Last Post: 08-07-2011, 01:49 AM
  3. Tight reservoir need help for production
    By amitkannojia in forum Reservoir
    Last Post: 12-02-2010, 03:51 PM
  4. tight gas reservoir
    By umair_865311 in forum Reservoir
    Last Post: 12-20-2009, 11:24 AM
  5. Tight Gas Reservoir
    By mzakii in forum Reservoir
    Last Post: 05-14-2009, 03:50 PM
