Originally Posted by
hermes
Hi, Ypal:
I don´t have experience with DSS Cladding, but I did a few projects with SS cladding on CS.
The problem is that each PWHT you do on the plate formed/welded, you are going to have a loss of properties from the cladding, because the dilution of C from CS into the SS structure.
To make it not so long, you should be very carefully when specify a PWHT in cladded CS plates.
When possible, you should have to do just one PWHT – a final PWHT - at the end of your fabrication process. During the fabrication process, any finished weld need to be heat treated in a final PWHT, should be postheated by a postweld hydrogen bakeout procedure (usually 2h at 250-300 Deg.Cent, then slowly cooled in still air) as stated in the WPS.
Hope it will help you. Regards.
Please read this link..
Cheers,
duazo2009
