Cvgd hgfj hgkfftkhf
Quote Originally Posted by freeman View Post
4.5.5 pipeline construction
4.5.5.1 pipeline design codes
most of the codes of practice are derivatives from studies conducted by the american society of mechanical engineers (asmie) and the american standards association (asa), which later changed its name to the american national standards institute (ansi).
The uk pipeline safety code is part 6 of the ip model code of safe practice in the petroleum industry, which includes and takes note of the british standard code of practice for pipelines, bs cp 2010, which relates to pipeline construction in the uk.
Gas distribution lines up to a working pressure of 70 bar are adequately covered by the institution of gas engineers’ series “recommendations on transmission and distribution practice. The iip code does not claim to be a design handbook and does not replace the need for appropriate experience and engineering judgment.
The ip code of practice sets forth general requirements for the safe design, construction and operation of pipelines for the conveyance of petroleum (crude oil and liquid products) and gas (natural gas and gaseous products).
It specifies considerations for pipe materials, flanges fittings and valves etc.
Submarine pipelines are designed to internationally accepted codes, such as in norway the det norske veritas “rules for the design, construction and inspection of submarine pipelines and pipeline risers”.
By definition pipelines normally start at the scraper launcher and ends at the scraper receiver or slug catcher.
It should be remembered that wherever national codes are more stringent than internationally accepted codes, the national codes must take precedence.
