Thread: Aspen Plus V8 crashing once i choose lauric acid
  1. Aspen Plus V8 crashing once i choose lauric acid
    Hi guys
    I want to ask do any of you having troubles simulating lauric acid using aspen plus? As i put lauric acid in the component side it always crashes
    the log state this
    [04:50:10]:Unhandled Exception
    Exception Message: An ItemsControl is inconsistent with its items source.
    See the inner exception for more information.
    Excetion Source: PresentationFramework
    StackTrace: at System.Windows.Controls.ItemContainerGenerator.Ver ify()
    at System.Windows.Controls.VirtualizingStackPanel.Mea sureChild(IItemContainerGenerator& generator, IContainItemStorage& itemStorageProvider, Object& parentItem, Boolean& hasUniformOrAverageContainerSizeBeenSet, Double& computedUniformOrAverageContainerSize, Boolean& computedAreContainersUniformlySized, IList& items, Object& item, IList& children, Int32& childIndex, Boolean& visualOrderChanged, Boolean& isHorizontal, Size& childConstraint, Rect& viewport, VirtualizationCacheLength& cacheSize, VirtualizationCacheLengthUnit& cacheUnit, Boolean& foundFirstItemInViewport, Double& firstItemInViewportOffset, Size& stackPixelSize, Size& stackPixelSizeInViewport, Size& stackPixelSizeInCacheBeforeViewport, Size& stackPixelSizeInCacheAfterViewport, Size& stackLogicalSize, Size& stackLogicalSizeInViewport, Size& stackLogicalSizeInCacheBeforeViewport, Size& stackLogicalSizeInCacheAfterViewport, Boolean& mustDisableVirtualization, Boolean isBeforeFirstItem, Boolean isAfterFirstItem, Boolean isAfterLastItem, Boolean skipActualMeasure, Boolean skipGeneration, Boolean& hasBringIntoViewContainerBeenMeasured, Boolean& hasVirtualizingChildren)
    at System.Windows.Controls.VirtualizingStackPanel.Mea sureOverrideImpl(Size constraint, Nullable`1 lastPageSafeOffset, List`1& previouslyMeasuredOffsets, Boolean remeasure)
    at System.Windows.Controls.VirtualizingStackPanel.Mea sureOverride(Size constraint)
    at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
    at System.Windows.UIElement.Measure(Size availableSize)
    at System.Windows.ContextLayoutManager.UpdateLayout()
    at System.Windows.ContextLayoutManager.UpdateLayoutCa llback(Object arg)
    at System.Windows.Media.MediaContext.InvokeOnRenderCa llback.DoWork()
    at System.Windows.Media.MediaContext.FireInvokeOnRend erCallbacks()
    at System.Windows.Media.MediaContext.RenderMessageHan dlerCore(Object resizedCompositionTarget)
    at System.Windows.Media.MediaContext.RenderMessageHan dler(Object resizedCompositionTarget)
    at System.Windows.Threading.ExceptionWrapper.Internal RealCall(Delegate callback, Object args, Int32 numArgs)
    at MS.Internal.Threading.ExceptionFilterHelper.TryCat chWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
    I hope someone knows whats the real problem
    thanks and many regards
  3. Re: Aspen Plus V8 crashing once i choose lauric acid
    I have no problems with lauric acid. I believe it is present in several databases, load more databases and try to pick lauric acid from another database
  1. Choose your own inspection software
    By ashfaqanwer in forum Mechanical Engineering
    Last Post: 11-26-2012, 03:42 PM
  2. How to choose Pumps?
    By tongdapump in forum Pipeline And Fluid Flow
    Last Post: 12-05-2011, 09:45 AM
  3. Replies: 0
    Last Post: 05-18-2011, 02:33 AM
