Thread: Using A350/LF2 instead of A105
  1. Using A350/LF2 instead of A105
    is there a limitation to use A350/LF2 instead of A105 forged material, there is no low temp. condition the working temp. assumed to be max. 200 C and the impact test is not required.
    also as i know A350/LF2 can used from -46C to 345C nd A105 can used from -29C to 427C is this information is documented and if please advice.
    Re: Using A350/LF2 instead of A105
    Check your construction code you´ll find your answers there, you´ll need the materials class (1 or 2).
  5. Re: Using A350/LF2 instead of A105
    Quote Originally Posted by ezat2007 View Post
    A350LF2 is requonized better than A105.
    In case of low temperature you need to check if class 1 or 2 is required (class 1 impact test @-46°C & class 2 impact test @-18°C).
    Many informations are available in each specification in ASME II A.
    For limitation in high temperature check in table 1A in ASME II D.
  1. which is the difference between ASTM A105 grade I y II??
    By waltherc82 in forum Mechanical Engineering
    Last Post: 01-22-2015, 10:44 PM
  2. ASTM A105 and A105N
    By subin in forum Mechanical Engineering
    Last Post: 02-09-2014, 12:18 PM
  3. A350 LF2 In Place of A105
    By ishaf5 in forum Materials Science &Corrosion
    Last Post: 04-18-2013, 05:15 PM
  4. ASTM A105 standard request
    By mestcrapp in forum Mechanical Engineering
    Last Post: 03-02-2011, 02:01 PM
