Originally Posted by
TBone
If your shut-in THP decreases from 300 to 140 this indicates that your fluid column is heavier, and this is consistent with the reported spike in water production. There doesnt have to be any "liquid loading" per se, you only have to produce with a high enough water cut. A wc of 80 % might not be a bad guess considering how much of the tubing is filled with water.
