Dear Friends I need your kind help and Guidance in the field of casing design for Geothermal and thermal Oil recovery well.
I want to know about:
1. load consideration for design of casing
2. Calculation of temperature profile ant Bottom hole and at surface
3. material selection and heat treatment process for OCTG
4. Design factors for different loads such as Collapse, Burst, tension, compression, Biaxial and triaxial.
5. centralization and cementing procedures and considerations for the well type mentioned.
I need the helps from you experts at this regards,
Thanks![]()
