Thread: Horizontal Well Test Analysis- Linear Flow
  1. Exclamation Horizontal Well Test Analysis- Linear Flow
    Does anyone knowst of a method to analyze the linear flow of a Build up test to obtain the average reservoir pressure? The well(s) I am analyzing are highly deviated displaying similar flow regimes as a horizontal well but the build up tests do not last long enough to see pseudo radial flow.
  2. Re: Horizontal Well Test Analysis- Linear Flow
    Try to use deviated well model in Saphir, in case of highly deviated well you should get response quiet similar to horizontal well. Here is a little manual for you -
  4. Re: Horizontal Well Test Analysis- Linear Flow
    After analyzing the response further, it is actually attributed to the geology of the formation (channel sands). The linear flow after the initial radial flow is a transition to the second flattening of the derivative due to a change of thickness of the sands. I have modeled it using a custom 2-D map i created in Ecrin. I am still wondering if there is a way to get the correct p* and eventually p average if only that linear flow is apparent.
  1. Article: Horizontal Well Test Analysis- Linear Flow
    By husamujahed in forum Home Articles
    Last Post: 07-10-2013, 04:24 AM
  2. Replies: 0
    Last Post: 02-06-2013, 07:40 AM
  3. Replies: 0
    Last Post: 07-21-2011, 10:31 PM
  4. Well Test Analysis
    By nazia.siddiqui7 in forum Reservoir
    Last Post: 09-04-2010, 01:45 PM
