Page 60 of 72 FirstFirst ... 10 50 58 59 60 61 62 70 ... LastLast
Results 709 to 720 of 860
Thread: International Engineering Standards
  1. Re: ÑÏ: International Engineering Standards
    Quote Originally Posted by subwil View Post
    Does anyone have ISO 9223, the newest or older?
    Thank you
    link to iso 9223-1992
  3. Re: ÑÏ: International Engineering Standards
    It is a redundancy in you link - two times "http://"
  5. Re: International Engineering Standards
    Please send me data rizy951@gmail.com
  6. #712
    hello, I need
    ASTM D1210 Edition 2010
    ASTM D281 Edition 2012
    ASTM D2369 Edition 2011
    ASTM D3359 Edition 2010
    ASTM D1640 Edition 2009
    who can help me?
    so many thanks
  7. Re: International Engineering Standards
    hello, I need
    NF ISO 13579-1 Avril 2013
    Fours industriels et équipements thermiques associés - Méthode de mesure du bilan énergétique et de calcul de l'efficacité
  9. Re: International Engineering Standards
    NEW Standard Documents
    internationalstandard2012@gmail.com
    SNV SN EN ISO 11073-10420
    3013.03.01 Health informatics - Personal health device communication - Part 10420: Device specialization - Body composition analyzer
    DS DS 2146.3
    Replaced by: DS/EN 283
    2040.01.01 Interchangeable lorry platforms - Requirements and testing
    NFPA 1965
    2014.01.01 Standard for Fire Hose Appliances - Effective Date: 02/03/2013
    ISO 14692-1
    2013.12.15 Industries du pétrole et du gaz naturel - Canalisations en plastique renforcé de verre (PRV) - Partie 1: Vocabulaire, symboles, applications et matériaux - Première édition
    ISO TR 20002
    2013.12.01 Information technology - Telecommunications and information exchange between systems - Managed P2P: Framework - First Edition
    ISO DIS 50002
    2013.06.13 Energy audits
    ISO 14443-3 DAM 6.2
    2013.06.06 Identification cards - Contactless integrated circuit cards - Proximity cards - Part 3: Initialization and anticollision AMENDMENT 6: Bit rates of 3fc/4, fc, 3fc/2 and 2fc
    ISO DIS 16443
    2013.06.06 Dentistry - Vocabulary of oral implantology
    ISO FDIS 11664-6
    2013.05.31 Colorimetry - Part 6: CIEDE2000 Colour-difference formula
    FAA AD 2013-08-22
    2013.05.28 To Prevent Uncontained Engine Failure And Damage To The Helicopter
    ISO DIS 16678
    2013.05.25 Guidelines for interoperable object identification and related authentication systems to deter counterfeiting and illicit trade
    FAA AD 2013-08-08
    2013.05.24 To Detect And Correct Fatigue -----ing Of The Skin Panel At The Specified Chem-Mill Step Locations
    FAA AD 2013-08-02
    2013.05.24 To Detect And Correct A -----ed Actuator Fitting Or Incorrectly Installed Bolts To The Actuator Fitting
    ISO DIS 13116
    2013.05.23 Dentistry - Test Method for Determining Radio-Opacity of Materials
    FAA AD 2013-08-03
    2013.05.23 To Prevent Fatigue Of The Wheel Axle Of The Main Landing Gear (MLG)
    FAA AD 2013-08-06
    2013.05.23 To Correct The Published Vne And To Correct The Indicated Airspeed
    FAA AD 2013-08-07
    2013.05.23 To Prevent ----- In The Outer Skin, Butt Strap, Or Fuselage Frame
    FAA AD 2013-08-04
    2013.05.23 To Detect -----s And Prevent The Part From Failing
    FAA AD 2013-08-09
    2013.05.23 To Prevent The Oxygen System Flex Line From Separating From The Hard Line
    ISO DIS 9934-3
    2013.05.23 Non-destructive testing - Magnetic particle testing - Part 3: Equipment
    FAA AD 2013-07-10
    2013.05.20 To Prevent Engine Fire And Damage To The Airplane
    FAA AD 2013-07-08
    2013.05.20 To Detect And Correct Defective Surfaces And Insufficient Thickness Of The Secondary Fuel Barrier
    FAA AD 2013-07-09
    2013.05.20 To Prevent An Ignition Source
    FAA AD 2013-07-01
    2013.05.20 To Prevent The MLG Jamming In The Gear Bay
    FAA AD 2013-07-11
    2013.05.20 To Detect And Correct Scribe Lines Which Can Develop Into Fatigue -----s In The Skin
    FAA AD 2013-07-04
    2013.05.20 To Prevent Failure Of The Attachment Points Of The YZ-Latches
    FAA AD 2013-07-07
    2013.05.20 To Prevent Premature Failure Of The Attach Pins
    FAA AD 2013-07-02
    2013.05.15 To Prevent The Potential Of Ignition Sources Inside Fuel Tanks
    FAA AD 2013-04-04
    2013.05.15 To Prevent Failure Of The Attachment Bolts And Consequent Separation Of A Thrust Reverser From The Airplane During Flight
    ISO DIS 13106.2
    2013.05.15 Plastics - Blow-moulded polypropylene containers for packaging of liquid foodstuffs
    ISO DIS 603-17.2
    2013.05.15 Bonded abrasive products - Dimensions - Part 17: Spindle mounted wheels
    ISO FDIS 5721-1
    2013.05.15 Agricultural tractors - Requirements, test procedures and acceptance criteria for the operator's field of vision - Part 1: Field of vision to the front
    FAA AD 2013-07-03
    2013.05.15 To Detect And Correct -----s And Damage To The Main And Central Landing Gear
    FAA AD 2013-07-05
    2013.05.15 To Prevent ----- In The Blending Radii Of The Center Windscreen
    FAA AD 2013-06-05
    2013.05.09 To Prevent Discrepancies In The Aft Attach Lugs Of The Elevator Tab Control Mechanism
    FAA AD 2013-06-07
    2013.05.09 To Prevent An Undetected Flight Display Error Of A Slow Drift In The Roll Axis, Disorientation Of The Pilot, And Subsequent Loss Of Control Of The Helicopter
    FAA AD 2013-06-06
    2013.05.08 To Prevent Failure Of OBV Ring Lock Fuel Fittings, Engine Fuel Leakage, Uncontrolled Fire, And Damage To The Airplane
    ISO DIS 17306
    2013.05.07 Petroleum products - Biodiesel - Determination of free and total glycerin and mono-, di- and tracylglycerols by gas chromatography
    FAA AD 2013-07-13
    2013.05.06 To Prevent Failure To Supply Oxygen Upon Demand To The Flight Crew In Flight In "100%" And "Emergency" Modes
    FAA AD 2013-07-06
    2013.05.06 To Prevent Degradation Of The Epicyclic Reduction Gear Module Within A Rotor Drive System Gearbox
    FAA AD 2013-06-04
    2013.05.03 To Detect And Correct Any Discrepancies With The Elevator Pushrod Assembly And The Horizontal Tail Structure
    FAA AD 2013-05-10
    2013.05.03 To Detect And Correct Corrosion In The Packboard Release Mechanisms
    FAA AD 2013-06-03
    2013.05.03 To Prevent Erroneous AOA Information And Consequent Delayed Or Non-Activation Of The AOA Protection Systems
    FAA AD 2013-05-12
    2013.05.03 To Prevent The Inability Of The Fire Extinguishing System To Suppress Fire
    VDE V 0830-2-11
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 11: Hold-up devices - Vornorm
    VDE 0493-1-6654
    2013.05.01 Measurement of radioactivity in the environment – Air: radon-222 – Part 4: Integrated measurement method for determining average activity concentration using passive sampling and delayed analysis
    VDE AR-E 2757-1
    2013.05.01 Ambient Assisted Living (AAL) – Terms and definitions
    ISO 20140-1
    2013.05.01 Automation systems and integration - Evaluating energy efficiency and other factors of manufacturing systems that influence the environment - Part 1: Overview and general principles - First Edition
    VDE 0830-2-2-72
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 2-7-2: Intrusion detectors – Glass break detectors (passive)
    VDE 0801-600-1
    2013.05.01 Information technology – Data centre facilities and infrastructures – Part 1: General concepts
    DIN EN ISO 25539-2
    2013.05.01 Cardiovascular implants - Endovascular devices - Part 2: Vascular stents (ISO 25539-2:2012); German version EN ISO 25539-2:2012
    DIN EN 3102
    2013.05.01 Aerospace series - Sealants - Test methods - Determination of low-temperature flexibility; German and English version EN 3102:2013
    DIN EN 62575-2
    2013.05.01 Radio frequency (RF) bulk acoustic wave (BAW) filters of assessed quality - Part 2: Guidelines for the use (IEC 62575-2:2012); German version EN 62575-2:2012
    DIN EN ISO 11269-2
    2013.05.01 Soil quality - Determination of the effects of pollutants on soil flora - Part 2: Effects of contaminated soil on the emergence and early growth of higher plants (ISO 11269-2:2012); German version EN ISO 11269-2:2013
    ISO 16191
    2013.05.01 Water quality - Determination of the toxic effect of sediment on the growth behaviour of Myriophyllum aquaticum - First Edition
    VDE 0875-15-1 BERICHTIGUNG 1
    2013.05.01 Limits and methods of measurement of radio disturbance characteristics of electrical lighting and similar equipment
    VDE V 0830-2-5-4
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 5-4: System compatibility testing for I&HAS equipments located in supervised premises - Vornorm
    VDE 0830-2-2-73
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 2-7-3: Intrusion detectors – Glass break detectors (active)
    ISO 81060-2
    2013.05.01 Non-invasive sphygmomanometers - Part 2: Clinical investigation of automated measurement type - Second Edition
    DIN SPEC 33440
    2013.05.01 Ergonomic design of user-interfaces and products for Smart Grid and Electromobility
    ISO 11357-2
    2013.05.01 Plastics - Differential Scanning Calorimetry (DSC) - Part 2: Determination of Glass Transition Temperature and Glass Transition Step Height - Second Edition
    ISO TR 14069
    2013.05.01 Greenhouse gases - Quantification and reporting of greenhouse gas emissions for organizations - Guidance for the application of ISO 14064-1 - First Edition
    VDE 0130-6-200
    2013.05.01 Fuel cell technologies – Part 6-200: Micro fuel cell power systems – Performance test methods
    DIN EN 16119
    2013.05.01 LPG equipment and accessories - Sealing caps and plugs for LPG cylinder and pressure vessel valves - Specification and testing; German version EN 16119:2013
    VDE 0687-512-24-1
    2013.05.01 Connectors for electronic equipment – Tests and measurements – Part 24-1: Magnetic interference tests – Test 24a: Residual magnetism
    VDE 0493-1-6652
    2013.05.01 Measurement of radioactivity in the environment – Air: radon-222 – Part 2: Integrated measurement method for determining average potential alpha energy concentration of its short-lived decay products
    DIN EN 1242
    2013.05.01 Adhesives - Determination of isocyanate content; German version EN 1242:2013
    DIN EN ISO 11148-3
    2013.05.01 Hand-held non-electric power tools - Safety requirements - Part 3: Drills and tappers (ISO 11148-3:2012); German version EN ISO 11148-3:2012
    DIN EN 16210
    2013.05.01 Transportation loads - Measurement and evaluation of climatic and other loads - Data acquisition and general requirements for measuring equipment; German version EN 16210:2013
    DIN EN 3682-007
    2013.05.01 Aerospace series - Connectors, plug and receptacle, electrical, rectangular, interchangeable insert type, rack to panel, operating temperature 150 °C continuous - Part 007: Size 3 plug - Product standard; German and English version EN 3682-007:2013
    VDE 0632-2-6
    2013.05.01 Switches for household and similar fixed electrical installations – Part 2-6: Particular requirements – Fireman’s switches for exterior and interior signs and luminaires
    VDE V 0302-994
    2013.05.01 Electrical Insulation systems (EIS) – Thermal evaluation of combined liquid and solid components – Part 1: General requirements - Vornorm
    VDE 0830-2-2-72
    DIN EN ISO 17636-2
    2013.05.01 Non-destructive testing of welds - Radiographic testing - Part 2: X- and gamma-ray techniques with digital detectors (ISO 17636-2:2013); German version EN ISO 17636-2:2013
    VDE 0830-2-2-73
    DIN EN 62150-3
    2013.05.01 Fibre optic active components and devices - Test and measurement procedures - Part 3: Optical power variation induced by mechanical disturbance in optical receptacles and transceiver interfaces (IEC 62150-3:2012); German version EN 62150-3:2012
    VDE 0660-117
    2013.05.01 Low-voltage switchgear and controlgear – Part 4-2: Contactors and motor-starters – AC semiconductor motor controllers and starters
    DIN CEN ISO/TS 18234-3
    2013.05.01 Intelligent transport systems - Traffic and travel information via transport protocol experts group, generation 1 (TPEG1) binary data format - Part 3: Service and network information (TPEG1-SNI) (ISO/TS 18234-3:2013); English version CEN ISO/TS 18234-3:2013
    DIN 14555-22
    2013.05.01 Vehicles carrying tools and gears - Part 22: GW-L2 for logistic tasks
    DIN EN ISO 16610-85
    2013.05.01 Geometrical product specifications (GPS) - Filtration - Part 85: Morphological areal filters: Segmentation (ISO 16610-85:2013); German version EN ISO 16610-85:2013
    DIN EN 16164
    2013.05.01 Water quality - Guidance standard for designing and selecting taxonomic keys; German version EN 16164:2013
    VDE 0830-2-2-71
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 2-7-1: Intrusion detectors – Glass break detectors (acoustic)
    DIN SPEC 12981
    2013.05.01 Micro process engineering - Testing of micro process components with explosible gas mixtures
    DIN EN 16283
    2013.05.01 Packaging - Flexible aluminium tubes - Test method to measure the force to pierce the membrane; German version EN 16283:2013
    DIN EN 3682-006
    2013.05.01 Aerospace series - Connectors, plug and receptacle, electrical, rectangular, interchangeable insert type, rack to panel, operating temperature 150 °C continuous - Part 006: Size 3 receptacle - Product standard; German and English version EN 3682-006:2013
    DIN EN 16143
    2013.05.01 Petroleum products - Determination of content of Benzo(a)pyrene (BaP) and selected polycyclic aromatic hydrocarbons (PAH) in extender oils - Procedure using double LC cleaning and GC/MS analysis; German version EN 16143:2013
    DIN EN ISO 24443
    2013.05.01 Determination of sunscreen UVA photoprotection in vitro (ISO 24443:2012); German version EN ISO 24443:2012
    VDE V 0830-2-11
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 11: Hold-up devices - Prestandard
    ISO 23006-1
    2013.05.01 Information technology - Multimedia service platform technologies - Part 1: Architecture - Second Edition
    DIN EN ISO 898-1
    2013.05.01 Mechanical properties of fasteners made of carbon steel and alloy steel - Part 1: Bolts, screws and studs with specified property classes - Coarse thread and fine pitch thread (ISO 898-1:2013); German version EN ISO 898-1:2013
    DIN EN 1604
    2013.05.01 Thermal insulating products for building applications - Determination of dimensional stability under specified temperature and humidity conditions; German version EN 1604:2013
    VDE 0471-11-4
    2013.05.01 Fire hazard testing – Part 11-4: Test flames – 50 W flame – Apparatus and confirmational test method
    VDE 0493-1-6653
    2013.05.01 Measurement of radioactivity in the environment – Air: radon-222 – Part 3: Spot measurement method of the potential alpha energy concentration of its short-lived decay products
    DIN CEN/TR 16478
    2013.05.01 Surveillance from first commissioning on measuring devices used in natural gas supply to the installations of the activities under the Directive 2003/87/EC establishing a scheme of CO<sub>2</sub> emissions trading; German version CEN/TR 16478:2012
    DIN CEN ISO/TS 18234-11
    2013.05.01 Intelligent transport systems - Traffic and Travel Information (TTI) via transport protocol experts group, generation 1 (TPEG1) binary data format - Part 11: Location Referencing Container (TPEG1-LRC) (ISO/TS 18234-11:2013); English version CEN ISO/TS 18234-11:2013
    VDE 0876-16-1-4
    2013.05.01 Specification for radio disturbance and immunity measuring apparatus and methods – Part 1-4: Radio disturbance and immunity measuring apparatus – Antennas and test sites for radiated disturbance measurements
    ISO 11357-2
    2013.05.01 Plastiques - Analyse calorimétrique différentielle (DSC) - Partie 2: Détermination de la température de transition vitreuse et de la hauteur de palier de transition vitreuse - Deuxième édition
    DIN SPEC 91289
    2013.05.01 Benchmarking of Outsourcing Services and Outsourcing Providers
    VDE 0493-1-6654
    ISO 8094
    2013.05.01 Steel cord conveyor belts - Adhesion strength test of the cover to the core layer - Second Edition
  10. Re: International Engineering Standards
    VDE 0471-7-3
    2013.05.01 Fire hazard testing – Part 7-3: Toxicity of fire effluent – Use and interpretation of test results
    DIN EN 3682-009
    2013.05.01 Aerospace series - Connectors, plug and receptacle, electrical, rectangular, interchangeable insert type, rack to panel, operating temperature 150 °C continuous - Part 009: Size 4 plug - Product standard; German and English version EN 3682-009:2013
    DIN EN 4492
    2013.05.01 Aerospace series - Non-metallic materials - Anaerobic polymerisable compounds - Threadlocking - Torque strength 19 Nm; German and English version of EN 4492:2013
    DIN EN 295-5
    2013.05.01 Vitrified clay pipe systems for drains and sewers - Part 5: Requirements for perforated pipes and fittings; German version EN 295-5:2013
    ISO TR 20152-3
    2013.05.01 Timber structures - Bond performance of adhesives - Part 3: Use of alternative species for bond tests - First Edition
    DIN EN 253
    2013.05.01 District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Pipe assembly of steel service pipe, polyurethane thermal insulation and outer casing of polyethylene; German version EN 253:2009+A1:2013
    VDE 0493-1-6651
    2013.05.01 Measurement of radioactivity in the environment – Air: radon-222 – Part 1: Origins of radon and its short-lived decay products and associated measurement methods
    VDE 0715-12
    2013.05.01 Miscellaneous lamps
    VDE 0801-600-1
    ISO 11529
    2013.05.01 Milling cutters - Designation - Shank-type and bore-type milling cutters of solid or tipped design or with indexable cutting edges - First Edition
    VDE 0632-2-6
    VDE 0493-1-6652
    DIN EN 16445
    2013.05.01 Ventilation for buildings - Air diffusion - Aerodynamic testing and rating for mixed flow application: non-isothermal procedure for cold jet; German version EN 16445:2013
    DIN EN 4629
    2013.05.01 Aerospace series - Steel X4CrNiMo16-5-1 (1.4418) - Air melted - Softened - Forging stock - D<sub>e</sub> ≤ 300 mm; German and English version EN 4629:2013
    VDE 0687-512-99-001
    2013.05.01 Connectors for electronic equipment – Tests and measurements – Part 99-001: Test schedule for engaging and separating connectors under electrical load – Test 99a: Connectors used in twisted pair communication cabling with remote power
    VDE V 0830-2-5-4
    2013.05.01 Alarm systems – Intrusion and hold-up systems – Part 5-4: System compatibility testing for I&HAS equipments located in supervised premises - Prestandard
    VDE AR-E 2100-712
    2013.05.01 Measures for the DC range of a PV installation for the maintenance of safety in the case of firefighting or technical assistance
    VDE 0493-1-6653
    VDE 0493-1-6651
    VDE 0042-4
    2013.05.01 Material declaration for products of and for the electrotechnical industry
    VDE 0471-7-2
    2013.05.01 Fire hazard testing – Part 7-2: Toxicity of fire effluent – Summary and relevance of test methods
    DIN 81249-2
    2013.05.01 Corrosion of metals in sea water and sea atmosphere - Part 2: Free corrosion in sea water; Text in German and English
    DIN CWA 16525
    2013.05.01 Multilingual electronic cataloguing and classification in eBusiness - Classification Mapping for open and standardized product classification usage in eBusiness; English version CWA 16525:2012
    DIN 16842
    2013.05.01 Polyethylene (PE) pipes - PE-HD for pressureless applications - General quality requirements, dimensions and testing; Text in German and English
    ISO 9660 AMD 1
    2013.05.01 Information processing - Volume and file structure of CD-ROM for information interchange AMENDMENT 1 - First Edition
    BSI PD CEN ISO/TR 15608
    2013.04.30 Welding — Guidelines for a metallic materials grouping system
    BSI BS EN 13877-2
    2013.04.30 Concrete pavements Part 2: Functional requirements for concrete pavements
    BSI BS EN 13877-1
    2013.04.30 Concrete pavements Part 1: Materials
    BSI BS 1881-125
    2013.04.30 Testing concrete — Part 125: Methods for mixing and sampling fresh concrete in the laboratory
    BSI BS EN 335
    2013.04.30 Durability of wood and wood-based products - Use classes: definitions, application to solid wood and wood-based products
    BSI BS EN 4266
    2013.04.30 Aerospace series — Bearing spherical plain, metal to metal, in corrosion resisting steel, cadmium plated — Wide series — Dimensions and loads — Inch series
    BSI BS ISO/IEC 29142-3
    2013.04.30 Information technology — Print cartridge characterization Part 3: Environment
    BSI BS EN 61300-2-19
    2013.04.30 Fibre optic interconnecting devices and passive components — Basic test and measurement procedures Part 2-19: Tests – Damp heat (steady state)
    BSI BS EN 13142
    2013.04.30 Ventilation for buildings — Components/products for residential ventilation — Required and optional performance characteristics
    BSI BS ISO 16304
    2013.04.30 Ships and marine technology — Marine environment protection — Arrangement and management of port waste reception facilities
    BSI BS EN 60335-2-17
    2013.04.30 Household and similar electrical appliances - Safety - Part 2-17: Particular requirements for blankets, pads, clothing and similar flexible heating appliances - AMD 16485: July 31, 2006; AMD: April 30, 2009
    BSI BS EN ISO 22413
    2013.04.30 Transfer sets for pharmaceutical preparations - Requirements and test methods
    BSI BS ISO 18436-8
    2013.04.30 Condition monitoring and diagnostics of machines — Requirements for qualification and assessment of personnel Part 8: Ultrasound
    BSI BS ISO 22197-5
    2013.04.30 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for air-purification performance of semiconducting photocatalytic materials Part 5: Removal of methyl mercaptan
    BSI BS ISO 6263
    2013.04.30 Hydraulic fluid power - Compensated flow-control valves - Mounting surfaces
    BSI BS ISO 25597
    2013.04.30 Stationary source emissions - Test method for determining PM2,5 and PM10 mass in stack gases using cyclone samplers and sample dilution
    BSI BS ISO 13165-1
    2013.04.30 Water quality - Radium-226 Part 1: Test method using liquid scintillation counting
    BSI BS EN 61968-1
    2013.04.30 Application integration at electric utilities — System interfaces for distribution management Part 1: Interface architecture and general requirements
    BSI BS ISO 16049-1
    2013.04.30 Air cargo equipment - Restraint straps Part 1: Design criteria and testing methods
    BSI PD ISO/IEC TR 13066-2
    2013.04.30 Information technology — Interoperability with Assistive Technology (AT) Part 2: Windows accessibility application programming interface (API)
    BSI BS EN ISO 6887-6
    2013.04.30 Microbiology of food and animal feed — Preparation of test samples, initial suspension and decimal dilutions for microbiological examination Part 6: Specific rules for the preparation of samples taken at the primary production stage
    BSI PD ISO/IEC TR 13066-3
    2013.04.30 Information technology — Interoperability with Assistive Technology (AT) Part 3: IAccessible2 accessibility application programming interface (API)
    BSI BS ISO 23893-3
    2013.04.30 Water quality — Biochemical and physiological measurements on fish Part 3: Determination of vitellogenin
    TC AD CF-2013-10
    2013.04.30 Flight Data And Cockpit Voice Recorder Paint/Marking Deterioration
    BSI PD ISO/TR 10295-3
    2013.04.30 Fire tests for building elements and components — Fire testing of service installations Part 3: Single component penetration seals — Guidance on the construction and use of test configurations and simulated services to characterise sealing materials
    BSI BS EN 16286-1
    2013.04.30 Railway applications — Gangway systems between vehicles Part 1: Main applications
    BSI BS EN ISO 15012-1
    2013.04.30 Health and safety in welding and allied processes — Equipment for capture and separation of welding fume Part 1: Requirements for testing and marking of separation efficiency
    BSI BS EN 61850-7-410
    2013.04.30 Communication networks and systems for power utility automation Part 7-410: Basic communication structure — Hydroelectric power plants — Communication for monitoring and control
    BSI PD ISO/TS 29284
    2013.04.30 Intelligent transport systems — Event-based probe vehicle data
    BSI BS EN ISO 29461-1
    2013.04.30 Air intake filter systems for rotary machinery — Test methods Part 1: Static filter elements
    BSI BS ISO 16354
    2013.04.30 Guidelines for knowledge libraries and object libraries
    BSI BS ISO 7176-16
    2013.04.30 Wheelchairs Part 16: Resistance to ignition of postural support devices
    BSI BS ISO/IEC 29155-1
    2013.04.30 Systems and software engineering — Information technology project performance benchmarking framework Part 1: Concepts and definitions
    BSI BS ISO 19701
    2013.04.30 Methods for sampling and analysis of fire effluents
    BSI BS EN 61924-2
    2013.04.30 Maritime navigation and radiocommunication equipment and systems — Integrated navigation systems Part 2: Modular structure for INS — Operational and performance requirements, methods of testing and required test results
    BSI BS EN 14214
    2013.04.30 Liquid petroleum products — Fatty acid methyl esters (FAME) for use in diesel engines and heating applications — Requirements and test methods
    BSI PD CEN/TS 16490
    2013.04.30 Fertilizers — Comparison of the CEN/TC 260/WG 7 ring test results with tolerances given in the Regulation (EC) Nr 2003/2003 Annex II and conclusions
    BSI BS ISO 14574
    2013.04.30 Fine ceramics (advanced ceramics, advanced technical ceramics) - Mechanical properties of ceramic composites at high temperature - Determination of tensile properties
    BSI BS ISO 14229-1
    2013.04.30 Road vehicles — Unified diagnostic services (UDS) Part 1: Specification and requirements
    BSI BS EN ISO 14644-10
    2013.04.30 Cleanrooms and associated controlled environments Part 10: Classification of surface cleanliness by chemical concentration
    BSI BS EN 62623
    2013.04.30 Desktop and notebook computers — Measurement of energy consumption
    BSI BS EN 12089
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Bending Behaviour
    BSI BS EN 12786
    2013.04.30 Safety of machinery - Requirements for the drafting of the vibration clauses of safety standards
    BSI BS ISO 11894-1
    2013.04.30 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for conductivity measurement of ion-conductive fine ceramics Part 1: Oxide-ion-conducting solid electrolytes
    BSI BS ISO 13125
    2013.04.30 Fine ceramics (advanced ceramics, advanced technical ceramics) - Test method for antifungal activity of semiconducting photocatalytic materials
    BSI BS ISO 16635-1
    2013.04.30 Dentistry — Dental rubber dam technique Part 1: Hole punch
    BSI BS EN 60349-4
    2013.04.30 Electric traction — Rotating electrical machines for rail and road vehicles Part 4: Permanent magnet synchronous electrical machines connected to an electronic converter
    BSI BS ISO 14346
    2013.04.30 Static design procedure for welded hollow-section joints — Recommendations
    BSI BS EN 61400-4
    2013.04.30 Wind turbines Part 4: Design requirements for wind turbine gearboxes
    BSI BS ISO 18097
    2013.04.30 Thermal insulating products for building equipment and industrial installations - Determination of maximum service temperature
    BSI BS EN 61674
    2013.04.30 Medical electrical equipment - Dosimeters with ionization chambers and/or semiconductor detectors as used in X-ray diagnostic imaging
    BSI BS ISO 14540
    2013.04.30 Hydraulic fluid power — Dimensions and requirements for screw-to-connect quickaction couplings for use at a pressure of 72 MPa (720 bar)
    BSI BS EN 302-7
    2013.04.30 Adhesives for load-bearing timber structures — Test methods Part 7: Determination of the working life under referenced conditions
    BSI PD ISO/TS 18234-8
    2013.04.30 Intelligent transport systems - Traffic and travel information via transport protocol experts group, generation 1 (TPEG1) binary data format Part 8: Congestion and Travel Time application (TPEG1-CTT)
    BSI BS EN 61499-1
    2013.04.30 Function blocks Part 1: Architecture
    BSI BS ISO 14541
    2013.04.30 Hydraulic fluid power — Dimensions and requirements for screw-to-connect quick-action couplings for general purpose
    BSI BS EN 302-6
    2013.04.30 Adhesives for load-bearing timber structures — Test methods Part 6: Determination of the minimum pressing time under referenced conditions
    BSI BS ISO 6106
    2013.04.30 Abrasive products — Checking the grain size of superabrasives
    BSI PD IEC/TS 62257-9-5
    2013.04.30 Recommendations for small renewable energy and hybrid systems for rural electrification Part 9-5: Integrated system - Selection of stand-alone lighting kits for rural electrification
    BSI BS ISO 21601
    2013.04.30 Corrosion of metals and alloys - Guidelines for assessing the significance of stress corrosion -----s detected in service
    BSI BS EN 61753-021-3
    2013.04.30 Fibre optic interconnecting devices and passive components — Performance standard Part 021-3: Single-mode fibre optic connectors for category U — Uncontrolled environment
    BSI PD CEN/TR 10261
    2013.04.30 Iron and steel - European standards for the determination of chemical composition
    BSI BS ISO 5902
    2013.04.30 Alpine skis - Determination of elastic properties
    BSI PD ISO/TR 25100
    2013.04.30 Intelligent transport systems - Systems architecture - Harmonization of ITS data concepts
    BSI BS EN 14894
    2013.04.30 LPG equipment and accessories - Cylinder and drum marking
    BSI BS EN 50110-1
    2013.04.30 Operation of electrical installations - Part 1: General requirements
    BSI BS ISO 11357-5
    2013.04.30 Plastics - Differential scanning calorimetry (DSC) Part 5: Determination of characteristic reaction-curve temperatures and times, enthalpy of reaction and degree of conversion
    BSI BS EN ISO 14065
    2013.04.30 Greenhouse gases - Requirements for greenhouse gas validation and verification bodies for use in accreditation or other forms of recognition
    BSI BS EN 302-4
    2013.04.30 Adhesives for load-bearing timber structures — Test methods Part 4: Determination of the effects of wood shrinkage on the shear strength
    BSI BS EN 62217
    2013.04.30 Polymeric HV insulators for indoor and outdoor use — General definitions, test methods and acceptance criteria
    BSI BS EN 12430
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Behaviour under Point Load
    BSI PD CEN/TS 16429
    2013.04.30 Stationary source emissions — Sampling and determination of hydrogen chloride content in ducts and stacks — Infrared analytical technique
    BSI BS ISO 18098
    2013.04.30 Thermal insulating products for building equipment and industrial installations — Determination of the apparent density of preformed pipe insulation
    BSI PD CEN/TR 16443
    2013.04.30 Backgrounds to the revision of EN 450-1:2005+A1:2007 — Fly ash for concrete
    BSI BS EN 12431
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Thickness for Floating Floor Insulating Products
  11. Re: International Engineering Standards
    VDE 0471-7-3
    DIN EN 3682-009
    DIN EN 4492
    DIN EN 295-5
    ISO TR 20152-3
    DIN EN 253
    VDE 0493-1-6651
    VDE 0715-12
    VDE 0801-600-1
    ISO 11529
    VDE 0632-2-6
    VDE 0493-1-6652
    DIN EN 16445
    DIN EN 4629
    VDE 0687-512-99-001
    VDE V 0830-2-5-4
    VDE AR-E 2100-712
    VDE 0493-1-6653
    VDE 0493-1-6651
    VDE 0042-4
    VDE 0471-7-2
    DIN 81249-2
    DIN CWA 16525
    DIN 16842
    ISO 9660 AMD 1
    BSI BS EN 13877-2
    BSI BS EN 13877-1
    BSI BS 1881-125
    BSI BS EN 335
    BSI BS EN 4266
    BSI BS EN 13142
    BSI BS ISO 16304
    BSI BS EN ISO 22413
    BSI BS ISO 18436-8
    BSI BS ISO 22197-5
    BSI BS ISO 6263
    BSI BS ISO 25597
    BSI BS ISO 13165-1
    BSI BS EN 61968-1
    BSI BS ISO 16049-1
    BSI BS ISO 23893-3
    TC AD CF-2013-10
    BSI BS EN 16286-1
    BSI PD ISO/TS 29284
    BSI BS ISO 16354
    BSI BS ISO 7176-16
    BSI BS ISO 19701
    BSI BS EN 61924-2
    BSI BS EN 14214
    BSI PD CEN/TS 16490
    BSI BS ISO 14574
    BSI BS ISO 14229-1
    BSI BS EN 62623
    BSI BS EN 12089
    BSI BS EN 12786
    BSI BS ISO 11894-1
    BSI BS ISO 13125
    BSI BS ISO 16635-1
    BSI BS EN 60349-4
    BSI BS ISO 14346
    BSI BS EN 61400-4
    BSI BS ISO 18097
    BSI BS EN 61674
    BSI BS ISO 14540
    BSI BS EN 302-7
    BSI BS EN 61499-1
    BSI BS ISO 14541
    BSI BS EN 302-6
    BSI BS ISO 6106
    BSI BS ISO 21601
    BSI PD CEN/TR 10261
    BSI BS ISO 5902
    BSI PD ISO/TR 25100
    BSI BS EN 14894
    BSI BS EN 50110-1
    BSI BS ISO 11357-5
    BSI BS EN ISO 14065
    BSI BS EN 302-4
    BSI BS EN 62217
    BSI BS EN 12430
    BSI PD CEN/TS 16429
    BSI BS ISO 18098
    BSI PD CEN/TR 16443
    BSI BS EN 12431
  12. Re: International Engineering Standards
    BSI BS EN 16304
    2013.04.30 Automatic vent valves for gas burners and gas burning appliances
    BSI PD CEN/TR 16468
    2013.04.30 Food analysis — Determination of pesticide residues by GC-MS — Retention times, mass spectrometric parameters and detector response information
    BSI BS EN 12091
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Freeze-Thaw Resistance
    BSI BS ISO 7133
    2013.04.30 Earth-moving machinery — Scrapers — Terminology and commercial specifications
    BSI BS ISO 13175-3
    2013.04.30 Implants for surgery - Calcium phosphates - Part 3: Hydroxyapatite and beta-tricalcium phosphate bone substitutes
    BSI BS ISO 8600-1
    2013.04.30 Endoscopes - Medical endoscopes and endotherapy devices - Part 1: General requirements
    BSI BS ISO 16482-1
    2013.04.30 Binders for paints and varnishes - Determination of the non-volatile-matter content of aqueous rosin-resin dispersions - Part 1: Oven method
    BSI BS ISO 16482-2
    2013.04.30 Binders for paints and varnishes — Determination of the non-volatile-matter content of aqueous rosin-resin dispersions - Part 2: Microwave method
    BSI BS ISO 18096
    2013.04.30 Thermal insulating products for building equipment and industrial installations — Determination of maximum service temperature for preformed pipe insulation
    BSI BS ISO 15781
    2013.04.30 Photography - Digital still cameras - Measuring shooting time lag, shutter release time lag, shooting rate, and start-up time
    BSI BS ISO 14230-2
    2013.04.30 Road vehicles — Diagnostic communication over K-Line (DoK-Line) Part 2: Data link layer
    BSI BS EN ISO 14910-1
    2013.04.30 Plastics — Thermoplastic polyester/ester and polyether/ester elastomers for moulding and extrusion Part 1: Designation system and basis for specification
    BSI BS EN ISO 21179
    2013.04.30 Light conveyor belts — Determination of the electrostatic field generated by a running light conveyor belt
    BSI BS ISO 525
    2013.04.30 Bonded abrasive products - General requirements
    BSI BS ISO/IEC 14143-2
    2013.04.30 Information technology — Software measurement — Functional size measurement Part 2: Conformity evaluation of software size measurement methods to ISO/IEC 14143-1
    BSI BS EN ISO 6873
    2013.04.30 Dentistry - Gypsum products
    BSI PD CEN/TR 16467
    2013.04.30 Playground equipment accessible for all children
    BSI BS ISO 14409
    2013.04.30 Ships and marine technology — Ship launching air bags
    BSI BS ISO/IEC 15940
    2013.04.30 Systems and software engineering — Software Engineering Environment Services
    BSI BS EN ISO 27789
    2013.04.30 Health informatics — Audit trails for electronic health records
    BSI BS EN ISO 14720-1
    2013.04.30 Testing of ceramic raw and basic materials — Determination of sulfur in powders and granules of nonoxidic ceramic raw and basic materials Part 1: Infrared measurement methods
    BSI PD ISO/TR 22201-3
    2013.04.30 Lifts (elevators), escalators and moving walks — Programmable electronic systems in safety related applications Part 3: Life cycle guideline for programmable electronic systems related to PESSRAL and PESSRAE
    BSI BS EN 15869-3
    2013.04.30 Inland navigation vessels — Electrical shore connection, three phase current 400 V, up to 63 A, 50 Hz Part 3: On-board unit, safety requirements
    BSI PD ISO/TR 16743
    2013.04.30 Optics and photonics — Wavefront sensors for characterising optical systems and optical components
    BSI PD IEC/TS 60076-19
    2013.04.30 Power transformers Part 19: Rules for the determinations of uncertainties in the measurement of losses in power transformers and reactors
    BSI BS ISO 11347
    2013.04.30 Ships and marine technology — Large yachts — Measurement and assessment of the visual appearance of coatings
    BSI PD ISO/TS 19139-2
    2013.04.30 Geographic information - Metadata - XML schema implementation Part 2: Extensions for imagery and gridded data
    BSI BS ISO 13122
    2013.04.30 Ships and marine technology — Launching appliances for davit-launched liferafts
    BSI BS ISO 24614-2
    2013.04.30 Language resource management — Word segmentation of written texts Part 2: Word segmentation for Chinese, Japanese and Korean
    BSI BS EN 302-1
    2013.04.30 Adhesives for load-bearing timber structures — Test methods Part 1: Determination of longitudinal tensile shear strength
    BSI BS EN ISO 14720-2
    2013.04.30 Testing of ceramic raw and basic materials - Determination of sulfur in powders and granules of nonoxidic ceramic raw and basic materials Part 2: Inductively coupled plasma optical emission spectrometry (ICP/OES) or ion chromatography after burning in an oxygen flow
    BSI BS ISO/IEC 7816-4
    2013.04.30 Identification cards - Integrated circuit cards - Part 4: Organization, security and commands for interchange
    BSI BS EN 302-3
    2013.04.30 Adhesives for load-bearing timber structures - Test methods Part 3: Determination of the effect of acid damage to wood fibres by temperature and humidity cycling on the transverse tensile strength
    BSI BS ISO 16446
    2013.04.30 Ships and Marine Technology — Marine Environmental Protection — Adaptor for Joining Dissimilar Boom Connectors
    FAA AD 2013-07-12
    2013.04.30 To Prevent Excessive Oil Consumption
    BSI BS ISO 7176-11
    2013.04.30 Wheelchairs Part 11: Test dummies
    BSI BS EN ISO 340
    2013.04.30 Conveyor belts - Laboratory scale flammability characteristics - Requirements and test method
    BSI BS EN ISO 13307
    2013.04.30 Microbiology of food and animal feed — Primary production stage — Sampling techniques
    BSI BS ISO 12815
    2013.04.30 Fibre-reinforced plastic composites — Determination of plain-pin bearing strength
    BSI BS ISO 12345
    2013.04.30 Diesel engines - Cleanliness assessment of fuel injection equipment
    BSI PD ISO/TR 17068
    2013.04.30 Information and documentation — Trusted third party repository for digital records
    BSI BS EN ISO 4892-2
    2013.04.30 Plastics - Methods of exposure to laboratory light sources - Part 2: Xenon-arc lamps
    BSI BS ISO 16900-3
    2013.04.30 Respiratory protective devices — Methods of test and test equipment Part 3: Determination of particle filter penetration
    BSI BS ISO 18099
    2013.04.30 Thermal insulating products for building equipment and industrial installations — Determination of the coefficient of thermal expansion
    BSI BS ISO/IEC 19794-14
    2013.04.30 Information technology — Biometric data interchange formats Part 14: DNA data
    BSI BS EN ISO 11553-3
    2013.04.30 Safety of machinery — Laser processing machines Part 3: Noise reduction and noise measurement methods for laser processing machines and hand-held processing devices and associated auxiliary equipment (accuracy grade 2)
    BSI BS EN ISO 14910-2
    2013.04.30 Plastics — Thermoplastic polyester/ester and polyether/ester elastomers for moulding and extrusion Part 2: Preparation of test specimens and determination of properties
    BSI BS EN 1316-2
    2013.04.30 Hardwood Round Timber - Qualitative Classification Part 2. Poplar
    BSI BS EN 4632-006
    2013.04.30 Aerospace series — Weldability and brazeability of materials in aerospace constructions Part 006: Homogeneous assemblies of titanium alloys
    BSI BS EN 14617-13
    2013.04.30 Agglomerated stone — Test methods Part 13: Determination of electrical resistivity
    BSI BS EN 14617-1
    2013.04.30 Agglomerated stone — Test methods Part 1: Determination of apparent density and water absorption
    BSI BS EN 16307-5
    2013.04.30 Industrial trucks — Safety requirements and verification Part 5: Supplementary requirements for pedestrian-propelled trucks
    BSI BS ISO 16929
    2013.04.30 Plastics — Determination of the degree of disintegration of plastic materials under defined composting conditions in a pilot-scale test
    BSI BS EN ISO 29462
    2013.04.30 Field testing of general ventilation filtration devices and systems for in situ removal efficiency by particle size and resi st ance t o ai rfl ow
    BSI BS EN 1807-1
    2013.04.30 Safety of woodworking machines — Band sawing machines Part 1: Table band saws and band re-saws
    BSI BS EN ISO 105-E01
    2013.04.30 Textiles - Tests for colour fastness Part E01: Colour fastness to water
    BSI BS EN 61499-2
    2013.04.30 Function blocks - Part 2: Software tools requirements
    BSI BS EN 1807-2
    2013.04.30 Safety of woodworking machines — Band sawing machines Part 2: Log sawing machines
    BSI BS EN 505
    2013.04.30 Roofing Products from Metal Sheets - Specification for Fully Supported Roofing Products of Steel Sheet
    BSI BS ISO 14934-2
    2013.04.30 Fire tests - Calibration and use of heat flux meters - Part 2: Primary calibration methods
    BSI BS EN 502
    2013.04.30 Roofing Products from Metal Sheet - Specification for Fully Supported Products of Stainless Steel Sheet
    BSI BS ISO/IEC 15504-5
    2013.04.30 Information technology — Process assessment Part 5: An exemplar software life cycle process assessment model
    BSI BS EN ISO 105-E04
    2013.04.30 Textiles - Tests for colour fastness Part E04: Colour fastness to perspiration
    FAA AD 2013-05-04
    2013.04.30 To Prevent Failure Of The Oil Pump Drive Shear Neck
    BSI BS ISO 2974
    2013.04.30 Diesel engines - 60 degree female cones for high-pressure fuel injection components
    BSI PD ISO/IEC TR 24748-3
    2013.04.30 Systems and software engineering - Life cycle management Part 3: Guide to the application of ISO/IEC 12207 (Software life cycle processes)
    BSI BS EN 61753-057-2
    2013.04.30 Fibre optic interconnecting devices and passive components — Performance standard Part 057-2: Single mode fibre plug-receptacle style optical fuse for category C — Controlled environment
    BSI PD IEC/TR 62222
    2013.04.30 Fire performance of communication cables installed in buildings
    BSI PD CLC/TR 50117-8
    2013.04.30 Coaxial cables used in cabled distribution networks Part 8: Repair and substitute of damaged buried cables
    BSI BS EN 1608
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Tensile Strength Parallel to Faces
    BSI BS ISO 11451-4
    2013.04.30 Road vehicles - Vehicle test methods for electrical disturbances from narrowband radiated electromagnetic energy - Part 4: Bulk current injection (BCI)
    BSI BS EN 12087
    2013.04.30 Thermal insulating products for building applications - Determination of long term water absorption by immersion
    BSI BS EN 13225
    2013.04.30 Precast concrete products - Linear structural elements
    BSI BS EN 12275
    2013.04.30 Mountaineering Equipment - Connectors - Safety Requirements and Test Methods
    BSI BS ISO/IEC 29115
    2013.04.30 Information technology — Security techniques — Entity authentication assurance framework
    BSI BS EN 1609
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Short Term Water Absorption by Partial Immersion
    BSI BS EN 302-5
    2013.04.30 Adhesives for load-bearing structures — Test methods Part 5: Determination of maximum assembly time under referenced conditions
    BSI BS ISO 22201-2
    2013.04.30 Lifts (elevators), escalators and moving walks - Programmable electronic systems in safety related applications Part 2: Escalators and moving walks (PESSRAE)
    BSI BS EN 71-4
    2013.04.30 Safety of toys Part 4: Experimental sets for chemistry and related activities
    BSI BS ISO 11938
    2013.04.30 Microbeam analysis — Electron probe microanalysis — Methods for elemental-mapping analysis using wavelength-dispersive spectroscopy
    BSI BS EN ISO 10121-2
    2013.04.30 Test methods for assessing the performance of gas-phase air cleaning media and devices for general ventilation Part 2: Gas-phase air cleaning devices (GPACD)
    BSI BS EN 14066
    2013.04.30 Natural stone test methods - Determination of resistance to ageing by thermal shock
    BSI BS EN ISO 11114-2
    2013.04.30 Gas cylinders — Compatibility of cylinder and valve materials with gas contents Part 2: Non-metallic materials
    BSI BS EN ISO 15609-6
    2013.04.30 Specification and qualification of welding procedures for metallic materials — Welding procedure specification Part 6: Laser-arc hybrid welding
    BSI BS EN ISO 13833
    2013.04.30 Stationary source emissions — Determination of the ratio of biomass (biogenic) and fossil-derived carbon dioxide — Radiocarbon sampling and determination
    BSI BS ISO 7176-3
    2013.04.30 Wheelchairs Part 3: Determination of effectiveness of brakes
    BSI BS EN 1504-5
    2013.04.30 Products and systems for the protection and repair of concrete structures — Definitions, requirements, quality control and evaluation of conformity Part 5: Concrete injection
    BSI BS ISO 7870-2
    2013.04.30 Control charts Part 2: Shewhart control charts
    BSI PD ISO/PAS 11819-4
    2013.04.30 Acoustics — Method for measuring the influence of road surfaces on traffic noise Part 4: SPB method using backing board
    BSI BS EN 12088
    2013.04.30 Thermal Insulating Products for Building Applications - Determination of Long Term Water Absorption by Diffusion
    FAA AD 2013-05-15
    2013.04.30 To Prevent The Failure Of The Floats To Inflate During An Emergency Landing
    FAA AD 2013-05-22
    2013.04.30 To Prevent Failure Of The Tail Rotor Pitch Control Link Assembly
    FAA AD 2013-05-16
    2013.04.30 To Detect A Short-Edge Margin Condition, Prevent Failure Of The Tailboom And Loss Of Control Of The Helicopter
    FAA AD 2013-05-21
    2013.04.30 To Prevent Failure Of The Blade, Jamming Of The Flight Controls, And Subsequent Loss Of Control Of The Helicopter
    BSI BS ISO 8528-5
    2013.04.30 Reciprocating internal combustion engine driven alternating current generating sets Part 5: Generating sets
    BSI BS EN 302-2
    2013.04.30 Adhesives for load-bearing timber structures — Test methods Part 2: Determination of resi stance to delamination
    BSI BS EN 1400
    2013.04.30 Child use and care articles - Soothers for babies and young children - Safety requirements and test methods
    BSI BS EN ISO 1797-3
    2013.04.30 Dentistry — Shanks for rotary instruments — Part 3: Shanks made of ceramics
    BSI PD ISO/TR 17209
    2013.04.30 Hydraulic fluid power — Two-, three-and four-port screw-in cartridge valves — Cavities with ISO 725 (UN and UNF) threads
    BSI BS EN 60191-6-22
    2013.04.30 Mechanical standardization of semiconductor devices Part 6-22: General rules for the preparation of outline drawings of surface mounted semiconductor device packages - Design guide for semiconductor packages Silicon Fine-pitch Ball Grid Array and Silicon Fine-pitch Land Grid Array (S-FBGA and S-FLGA)
  13. Re: International Engineering Standards
    BSI BS ISO 14229-6
    2013.04.30 Road vehicles — Unified diagnostic services (UDS) Part 6: Unified diagnostic services on K-Line implementation (UDSonK- Line)
    BSI PD IEC/TS 62850
    2013.04.30 Safety requirements for electrical equipment for measurement, control, and laboratory use — General requirements for equipment intended to be used in educational establishments by children
    BSI BS EN 16153
    2013.04.30 Light transmitting flat multiwall polycarbonate (PC) sheets for internal and external use in roofs, walls and ceilings — Requirements and test methods
    BSI PD ISO/IEC TR 24748-2
    2013.04.30 Systems and software engineering — Life cycle management Part 2: Guide to the application of ISO/IEC 15288 (System life cycle processes)
    ASME B16.5
    2013.04.29 Pipe Flanges and Flanged Fittings NPS 1/2 Through NPS 24 Metric/Inch Standard
    AFNOR NF ISO 3864-4
    2013.04.27 Graphical symbols - Safety colours and safety signs - Part 4 : colorimetric and photometric properties of safety sign materials
    AFNOR NF EN 301908-18
    2013.04.27 IMT cellular networks - Harmonized EN covering the essential requirements of article 3.2 of the R&TTE Directive - Part 18 : E-UTRA, UTRA and GSM/EDGE Multi-Standard -Radio (MSR) Base Station (BS) (V6.1.1)
    AFNOR NF EN 4199-001
    2013.04.27 Aerospace series - Bonding straps for aircraft - Part 001 : technical specification
    AFNOR NF ISO 10115
    2013.04.27 Essential oil of tarragon (Artemisia dracunculus L.)
    AFNOR NF EN ISO 16911-2
    2013.04.27 Stationary source emissions - Manual and automatic determination of velocity and volume flow rate in ducts - Part 2 : automated measuring systems
    AFNOR NF P23-311
    2013.04.27 Wooden interior doors and doorsets - Technical specification
    AFNOR NF EN 15153-1
    2013.04.27 Railway applications - External visible and audible warning devices for trains - Part 1 : head, marker and tail lamps
    AFNOR NF EN ISO 16911-1
    2013.04.27 Stationary source emissions - Manual and automatic determination of velocity and volume flow rate in ducts - Part 1 : manual reference method
    AFNOR NF ISO 17724
    2013.04.27 Graphical symbols - Vocabulary
    AFNOR NF EN 14319-1
    2013.04.27 Thermal insulating products for building equipment and industrial installations - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate (PIR) products - Part 1 : specification for the rigid foam dispensed system before installation
    AFNOR NF EN ISO 14644-10
    2013.04.27 Cleanrooms and associated controlled environments - Part 10 : classification of surface cleanliness by chemical concentration
    AFNOR NF ISO 3864-1
    2013.04.27 Graphical symbols - Safety colours and safety signs - Part 1 : design principles for safety signs and safety markings
    AFNOR NF EN 1080
    2013.04.27 Impact protection helmets for young children
    AFNOR NF ISO 4000-1
    2013.04.27 Passenger car tyres and rims - Part 1 : tyres (metric series)
    AFNOR NF EN ISO 294-5
    2013.04.27 Plastics - Injection moulding of test specimens of thermoplastic materials - Part 5 : preparation of standard specimens for investigating anisotropy
    AFNOR NF EN 14319-2
    2013.04.27 Thermal insulating products for building equipment and industrial installations - In-situ formed dispensed rigid polyurethane (PUR) and polyisocyanurate foam (PIR) products - Part 2 : specification for the installed insulation products
    FAA AD 2013-05-17
    2013.04.26 To Prevent Malfunction Of An Internal Valve, Power Loss At A Critical Phase Of Flight, And Loss Of Control Of The Helicopter
    FAA AD 2013-05-14
    2013.04.26 To Prevent Failure Of An Outer Ring Because Of -----ing
    ISO DIS 11118.2
    2013.04.26 Gas cylinders - Non-refillable metallic gas cylinders - Specification and test methods
    ISO FDIS 4833-2
    2013.04.25 Microbiology of food and animal feed - Horizontal method for the enumeration of microorganisms - Part 2: Colony count at 30 degrees C by the surface plating technique
    ISO DIS 12228-1
    2013.04.25 Animal and vegetable fats and oils - Determination of individual and total sterols content by gas chromatography - Part 1: Animal and vegetable fats and oils
    FAA AD 2013-05-07
    2013.04.25 To Prevent Moisture From Collecting And Freezing On The Elevator Control System Components
    FAA AD 2013-05-05
    2013.04.25 To Prevent Contactor Failures
    FAA AD 2013-05-03
    2013.04.25 To Prevent Electrical Current From Flowing Through A Motor-Operated Valve (MOV) Actuator Into A Fuel Tank
    FAA AD 2013-05-18
    2013.04.25 To Prevent Engine Fuel Leaks
    ISO FDIS 4833-1
    2013.04.25 Microbiology of food and animal feed - Horizontal method for the enumeration of microorganisms - Part 1: Colony count at 30 degrees C by the pour plate technique
    FAA AD 2013-05-19
    2013.04.24 To Prevent Uncontained Turbine Disc Fracture And Damage To The Airplane
    FAA AD 2013-05-20
    FAA AD 2013-05-06
    2013.04.24 To Prevent Jamming/Malfunctioning Of The Left-Hand Engine Thrust Control Mechanism
    FAA AD 2013-05-23
    2013.04.24 To Detect Deterioration Of The MRH Bearing And To Prevent Overloading The Scissor Links
    FAA AD 2013-05-13
    2013.04.24 To Prevent Failure Of The Engine And Loss Of The Airplane
    FAA AD 2013-06-01
    2013.04.24 To Prevent Failure Of The LPC Rotor Disc Assembly, Uncontained Engine Failure, And Damage To The Airplane
    FAA AD 2013-05-09
    2013.04.24 To Prevent A Short Circuit Of The Isolation Valve And Consequent Non-Closure Of The Isolation Valve
    FAA AD 2010-NM-020 WITHDRAWAL
    2013.04.23 To Minimize The Risk Of Smoke Or Flames In The Passenger Cabin By Installing A Switch In The Flight Compartment To Enable The Flightcrew To Turn Off Electrical Power To The IFE System And Other Nones; Withdrawal
    ISO DIS 14496-30
    2013.04.23 Information technology - Coding of audio-visual objects - Part 30: Timed Text and other visual overlays in ISO Base Media File Format
    ISO DIS 25063.3
    2013.04.23 Systems and software engineering - Systems and software product Quality Requirements and Evaluation (SQuaRE) - Common Industry Format (CIF) for usability: Context of use description
    TC AD CF-2013-09
    2013.04.23 Fuel System – Insufficient Clearance Between Fuel Line And Structure
    JSA JIS B 0216-3
    2013.04.22 ISO metric trapezoidal screw threads - Basic dimensions
    JSA JIS B 0216-2
    2013.04.22 ISO metric trapezoidal screw threads - Part 2: General plan
    JSA JIS B 0216-1
    2013.04.22 ISO metric trapezoidal screw threads - Part 1: Basic profiles and maximum material profiles
    UKCAA IN-2013/059
    2013.04.22 Information Notice - Farnborough LARS (West) Frequency Monitoring SSR Code
    JSA JIS B 0217-2
    2013.04.22 ISO metric trapezoidal screw threads - Tolerances - Part 2: Limits of sizes for external and internal screw thread
    JSA JIS B 0217-1
    2013.04.22 ISO metric trapezoidal screw threads - Tolerances - Part 1: Principles and basic data
    JSA JIS B 0101
    2013.04.22 Screw threads and fasteners - Vocabulary
    FAA AD 2010-NM-022 WITHDRAWAL
    2013.04.22 To Ensure That The Flightcrew Is Able To Turn Off Electrical Power To The IFE System And Other Non-Essential Electrical Systems Through A Switch In The Flight Compartment In The Event Of Smoke Or Flames; Withdrawal
    FAA AD 2008-SW-029
    2013.04.22 To Prevent Interference Between The Tail Gearbox (TGB) Attachment Bolt And The Structure Fitting
    FAA AD 2012-SW-058
    2013.04.22 To Identify And Correct An Inoperative Control Box Assembly
    FAA AD 2010-NM-019 WITHDRAWAL
    FAA AD 2013-NM-027
    2013.04.22 To Detect And Correct -----ing Of The Forward Support Fitting Assembly
    FAA AD 2012-SW-063
    2013.04.22 To Prevent Failure Of The No. 1 Engine Forward Firewall Center Fire Extinguisher Discharge Tube To Discharge An Extinguishing Agent For Complete Coverage Of The No. 1 Engine Compartment Area
    JSA JIS K 7015
    2013.04.22 Pultruded fibre-reinforced plastics
    FAA AD 2010-SW-107
    2013.04.22 To Prevent Incorrect Rigging Results
    FAA AD 2010-NM-021 WITHDRAWAL
    FAA AD 2009-SW-049
    2013.04.22 To Prevent Excessive Vibration Of The Helicopter And Loss Of Control Of The Helicopter
    UKCAA CAP 493 SI
    2013.04.22 Manual of Air Traffic Services Part 1 Supplementary Instruction - 2013/01
    ISO DIS 12647-5
    2013.04.22 Graphic technology - Process control for the manufacture of half-tone colour separations, proof and production prints - Part 5: Screen printing
    ISO DIS 13179-1.2
    2013.04.22 Implants for surgery - Plasma-sprayed unalloyed titanium coatings on surgical implants - Part 1: General requirements
    ISO DIS 14285.2
    2013.04.22 Rubber and plastics gloves for food services - Limits for extractable substances
    ISO DIS 13322-1.2
    2013.04.22 Particle size analysis - Image analysis methods - Part 1: Static image analysis methods
    AFNOR NF B52-001-1/A1
    2013.04.20 Regulations governing the use of timber in structure - Visual classification for the use of french softwood and hardwood species in structures - Part 1 : massive wood
    AFNOR NF EN 45545-1
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 1 : general
    AFNOR NF ISO 3308
    2013.04.20 Routine analytical cigarette-smoking machine - Definitions and standard conditions
    AFNOR NF EN 3660-038
    2013.04.20 Aerospace series - Cable outlet accessories for circular and rectangular electrical and optical connectors - Part 038 : manual installation tool, style Z, for installation of stainless steel shield termination band EN 3660-033, to cable outlet accessories - Product standard
    AFNOR NF EN ISO 12217-3
    2013.04.20 Small craft - Stability and buoyancy assessment and categorization - Part 3 : boats of hull length less than 6 m
    AFNOR NF EN 45545-3
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 3 : fire resistance requirements for fire barriers
    AFNOR NF M88-121
    2013.04.20 Tanks for transport of dangerous liquid goods with design pressure not exceeding 50 kPa - Single unloading valves
    AFNOR NF ISO 6588-1
    2013.04.20 Paper, board and pulps - Determination of pH of aqueous extracts - Part 1 : cold extraction
    AFNOR NF EN 14052/IN1
    2013.04.20 High performance industrial helmets
    AFNOR NF EN 3660-027
    2013.04.20 Aerospace series - Cable outlet accessories for circular and rectangular electrical and optical connectors - Part 027 : cable outlet, style A, 45°, unsealed, with cable tie strain relief for EN 3646 - Product standard
    AFNOR NF EN 228
    2013.04.20 Automotive fuels - Unleaded petroleum - Requirements and test methods
    AFNOR NF EN 45545-7
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 7 : fire safety requirements on flammable liquid and flammable gas installations
    AFNOR NF EN 16445
    2013.04.20 Ventilation for buildings - Air Diffusion - Aerodynamic testing and rating for mixed flow application : non-isothermal procedure for cold jet
    AFNOR NF ISO 1832
    2013.04.20 Indexable inserts for cutting tools - Designation
    AFNOR NF EN ISO 12217-2
    2013.04.20 Small craft - Stability and buoyancy assessment and categorization - Part 2 : sailing boats of hull length greater than or equal to 6 m
    AFNOR NF EN 12697-46
    2013.04.20 Bituminous mixtures - Test methods for hot mix asphalt - Part 46 : low temperature -----ing and properties by uniaxial tension tests
    AFNOR NF EN 45545-2
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 2 : requirements for fire behavior of materials and components
    AFNOR NF EN 14052+A1
    AFNOR NF B54-040/A1
    2013.04.20 Wood profiles for floor decking - Specifications
    AFNOR NF EN ISO 4892-2
    2013.04.20 Plastics - Methods of exposure to laboratory light sources - Part 2 : xenon-arc lamps
    AFNOR NF P84-500
    2013.04.20 Geomembranes - Dictionary of terms dealing with geomembranes
    AFNOR NF EN 45545-6
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 6 : fire control and management systems
    AFNOR NF ISO 6588-2
    2013.04.20 Paper, board and pulps - Determination of pH of aqueous extracts - Part 2 : hot extraction
    AFNOR NF EN ISO 12217-1
    2013.04.20 Small craft - Stability and buoyancy assessment and categorization - Part 1 : non-sailing boats of hull length greater than or equal to 6 m
    AFNOR NF EN 45545-4
    2013.04.20 Railway applications - Fire protection on railway vehicles - Part 4 : fire safety requirements for rolling stock design
    AFNOR NF EN 3660-025
    2013.04.20 Aerospace series - Cable outlet accessories for circular and rectangular electrical and optical connectors - Part 025 : cable outlet, style A, straight, unsealed, with cable tie strain relief for EN 3646 - Product standard
    AFNOR NF EN ISO 16180
    2013.04.20 Small craft - Navigation lights - Installation, placement and visibility
    AFNOR NF ISO 13444
    2013.04.20 Technical product documentation (TPD) - Dimensioning and indication of knurling
    AFNOR NF EN ISO 472
    2013.04.20 Plastics - Vocabulary
    AFNOR NF B52-001-2/A1
    2013.04.20 Regulations governing the use of timber in structures - Visual classification for the use of french softwood and hardwood species in structure - Part 2 : alternative method for massive wood used for manufacturing glued laminated timber BLC and glued solid timber BMR
    ISO FDIS 3166-1
    2013.04.19 Codes for the representation of names of countries and their subdivisions - Part 1: Country codes
    SAI AS/NZS 8811.1
    2013.04.19 Methods of testing infant products Method 1: Sleep surfaces-Test for firmness
    ISO FDIS 3166-2
    2013.04.19 Codes for the representation of names of countries and their subdivisions - Part 2: Country subdivision code
    SAI AS/NZS 60884.1
    2013.04.19 Plugs and socket-outlets for household and similar purposes Part 1: General requirements
    SAI AS 3533.4.2
    2013.04.19 Amusement rides and devices Part 4.2: Specific requirements-Contained play facilities
    EASA TCDS BA.017
    2013.04.19 Type Certificate Data Sheet - BAL&#211;NY KUB&#205;ČEK spol. s r.o. – BB-S - Issue 14
  14. Re: International Engineering Standards
    BSI BS ISO 14229-6
    BSI PD IEC/TS 62850
    BSI BS EN 16153
    ASME B16.5
    AFNOR NF ISO 3864-4
    AFNOR NF ISO 10115
    AFNOR NF P23-311
    AFNOR NF EN 15153-1
    AFNOR NF ISO 17724
    AFNOR NF EN 14319-1
    AFNOR NF ISO 3864-1
    AFNOR NF EN 1080
    AFNOR NF ISO 4000-1
    AFNOR NF EN 14319-2
    FAA AD 2013-05-17
    FAA AD 2013-05-14
    ISO DIS 11118.2
    ISO FDIS 4833-2
    ISO DIS 12228-1
    FAA AD 2013-05-07
    FAA AD 2013-05-05
    FAA AD 2013-05-03
    FAA AD 2013-05-18
    ISO FDIS 4833-1
    FAA AD 2013-05-19
    FAA AD 2013-05-20
    FAA AD 2013-05-06
    FAA AD 2013-05-23
    FAA AD 2013-05-13
    FAA AD 2013-06-01
    FAA AD 2013-05-09
    ISO DIS 14496-30
    ISO DIS 25063.3
    TC AD CF-2013-09
    JSA JIS B 0216-3
    JSA JIS B 0216-2
    JSA JIS B 0216-1
    UKCAA IN-2013/059
    JSA JIS B 0217-2
    JSA JIS B 0217-1
    JSA JIS B 0101
    FAA AD 2008-SW-029
    FAA AD 2012-SW-058
    FAA AD 2013-NM-027
    FAA AD 2012-SW-063
    JSA JIS K 7015
    FAA AD 2010-SW-107
    FAA AD 2009-SW-049
    UKCAA CAP 493 SI
    ISO DIS 12647-5
    ISO DIS 13179-1.2
    ISO DIS 14285.2
    ISO DIS 13322-1.2
    AFNOR NF EN 45545-1
    AFNOR NF ISO 3308
    AFNOR NF EN 45545-3
    AFNOR NF M88-121
    AFNOR NF ISO 6588-1
    AFNOR NF EN 228
    AFNOR NF EN 45545-7
    AFNOR NF EN 16445
    AFNOR NF ISO 1832
    AFNOR NF EN 45545-2
    AFNOR NF B54-040/A1
    AFNOR NF P84-500
    AFNOR NF EN 45545-6
    AFNOR NF ISO 6588-2
    AFNOR NF EN 45545-4
    AFNOR NF ISO 13444
    AFNOR NF EN ISO 472
    ISO FDIS 3166-1
    SAI AS/NZS 8811.1
    ISO FDIS 3166-2
    SAI AS/NZS 60884.1
    SAI AS 3533.4.2
    EASA TCDS BA.017
  16. Re: International Engineering Standards
    EASA PART-145 COA VAL-CAN
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Valid Approvals For Organisations Located In Canada
    EASA PART-145 COA VAL-NB
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Valid Approvals List Of Non-Bilateral EASA Part-145 Approved Organisations
    EASA PART-145 COA NOT VAL-NB
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Not Valid Approvals List Of Non-Bilateral EASA Part-145 Approved Organisations
    EASA PART-147 COA VAL-NB
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-147 Valid Approvals List Of Non-Bilateral EASA Part-147 Approved Organisations
    EASA PART-147 COA NOT VAL-NB
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-147 Not Valid Approvals List Of Non-Bilateral EASA Part-147 Approved Organisations
    EASA PART-145 COA NOT VAL-CAN
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Not Valid Approvals For Organisations Located In Canada
    EASA PART-145 COA NOT INV/SUSP-CAN
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Not Invalid/Suspended Approvals For Organisations Located In Canada
    EASA PART-145 COA INV/SUSP-US
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Invalid/Suspended Approvals For Organisations Located In The United States
    EASA PART-145 COA NOT VAL-US
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Not Valid Approvals For Organisations Located In The United States
    ITU-T T.38 NOTE
    2013.04.19 Procedures for real-time Group 3 facsimile communication over IP networks - Study Group 16
    EASA PART-145 COA VAL-US
    2013.04.19 Certification Organisation Approvals - Foreign EASA Part-145 Valid Approvals For Organisations Located In The United States
    FAA 78 FR 23626A
    2013.04.19 Agency Information Collection Activities; Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Report Of Inspections Required By Airworthiness Directives
    FAA 78 FR 23627A
    2013.04.19 Agency Information Collection Activities: Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Certification Of Aircraft And Airmen For The Operation Of Light-Sport Aircraft
    FAA 78 FR 23628A
    2013.04.19 Agency Information Collection Activities; Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Bird/Other Wildlife Strike Report
    FAA 78 FR 23626
    2013.04.19 Agency Information Collection Activities; Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Automatic Dependent Surveillance-Broadcast (ADS-B) Out Performance Requirements To Support Air Traffic Control (ATC) Service
    FAA 78 FR 23627
    2013.04.19 Agency Information Collection Activities: Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Fractional Aircraft Ownership Programs
    FAA 78 FR 23628
    2013.04.19 Agency Information Collection Activities; Requests For Comments; Clearance Of Renewed Approval Of Information Collection: Aircraft Noise Certification Documents For International Operations
    FAA 78 FR 23629
    2013.04.19 Office Of Commercial Space Transportation; Notice Of Availability And Request For Comment On The Draft Environmental Impact Statement For The SpaceX Texas Launch Site
    UL 60730-2-10 BULLETIN
    2013.04.19 UL Standard for Safety Automatic Electrical Controls for Household and Similar Use; Part 2: Particular Requirements for Motor Starting Relays - COMMENTS DUE: June 18, 2013
    ISO FDIS 14031
    2013.04.18 Environmental management - Environmental performance evaluation - Guidelines
    ISO DIS 16960
    2013.04.18 Natural gas - Determination of sulfur compounds - Determination of total sulfur by oxidative microcoulometry method
    ISO FDIS 13015
    2013.04.18 Woven fabrics - Distortion - Determination of skew and bow
    SAI AS ISO 12647.3
    2013.04.18 Graphic technology-Process control for the production of half-tone colour separations, proofs and production prints Part 3: Coldset offset lithography on newsprint
    OPNAV NOTE 5400 13U102242
    2013.04.18 (SER DNS-33/13U102242) DISESTABLISHMENT OF COMMANDER, MIDDLE EAST FORCE
    NASA NPR 7123.1 REV B
    2013.04.18 NASA Systems Engineering Processes and Requirements
    UNI UNI EN ISO 14910-1
    2013.04.18 Plastics - Thermoplastic polyester /ester and polyether/ester elastomers for moulding and extrusion - Part 1: Designation system and basis for specifications
    UNI UNI EN 502
    2013.04.18 Roofing products from metal sheet - Specification for fully supported roofing products of stainless steel sheet
    UNI UNI EN ISO 5840-3
    2013.04.18 Cardiovascular implants - Cardiac valve prostheses - Part 3: Heart valve substitutes implanted by transcatheter techniques
    EASA PAD 13-056
    2013.04.18 ATA 72 - Engine – Crankcase Assembly Opening – Sealing - Comment Period Expires May 16, 2013
    FAA 78 FR 23329A
    2013.04.18 Notice Of Release From Federal Surplus Property And Grant Assurance Obligations At Oroville Municipal Airport (OVE), Oroville, California
    EASA AD 2013-0096
    2013.04.18 ATA 72 - Engine – Intermediate Pressure Turbine Blades – Inspection
    UNI UNI EN 567
    2013.04.18 Mountaineering equipment - Rope clamps - Safety requirements and test methods
    UNI UNI EN 16345
    2013.04.18 Bitumen and bituminous binders - Determination of efflux time of bituminous emulsions using the Redwood No. II Viscometer
    UNI UNI EN ISO 11269-2
    2013.04.18 Soil quality - Determination of the effects of pollutants on soil flora - Part 2: Effects of contaminated soil on the emergence and early growth of higher plants
    UNI UNI EN ISO 25745-1
    2013.04.18 Energy performance of lifts, escalators and moving walks - Part 1: Energy measurement and verification
    UNI UNI EN 335
    2013.04.18 Durability of wood and wood-based products - Use classes: definitions, application to solid wood and wood-based products
    UNI UNI EN 1047-2
    2013.04.18 Secure storage units - Classification and methods of test for resistance to fire - Part 2: Data rooms and data container
    UNI UNI EN ISO 14798
    2013.04.18 Lifts (elevators), escalators and moving walks - Risk assessment and reduction methodology
    UNI UNI EN 16153
    2013.04.18 Light transmitting flat multiwall polycarbonate (PC) sheets for internal and external use in roofs, walls and ceilings - Requirements and test methods
    UNI UNI EN 480-15
    2013.04.18 Admixtures for concrete, mortar and grout - Test methods - Part 15: Reference concrete and method for testing viscosity modifying admixtures
    UNI UNI EN 1910
    2013.04.18 Wood flooring and wood panelling and cladding - Determination of dimensional stability
    UNI UNI EN 16292
    2013.04.18 Glass packaging - Screw finishes - Depressed threads
    ISO DIS 16198
    2013.04.18 Soil quality - Plant-based biotest to assess the environmental bioavailability of trace elements to plants
    UNI UNI EN 1609
    2013.04.18 Thermal insulating products for building applications - Determination of short term water absorption by partial immersion
    UNI EC 1-2013 UNI EN 10250-1
    2013.04.18 Open die steel forgings for general engineering purposes - General requirements
    UNI UNI EN 12087
    2013.04.18 Thermal insulating products for building applications - Determination of long term water absorption by immersion
    UNI UNI EN 16291-1
    2013.04.18 Glass packaging - Screw finishes for pressure capsules - Part 1: Returnable glass MCA 2 finish
    UNI UNI EN ISO 21179
    2013.04.18 Light conveyor belts - Determination of the electrostatic field generated by a running light conveyor belt
    UNI UNI EN 13877-1
    2013.04.18 Concrete pavements - Part 1: Materials
    FAA 78 FR 23329
    2013.04.18 Aircraft Access To SWIM Working Group Meeting
    UNI UNI/TS 11325-2
    2013.04.18 Pressure equipment - Putting into service and use of pressure equipment and assemblies - Part 2: Assessment procedure of fitness for service of pressure equipment working under creep conditions
    UKCAA IN-2013/058
    2013.04.18 Information Notice - UL 722 – Extended Operational Hours
    UNI UNI EN ISO 105-E02
    2013.04.18 Textiles - Tests for colour fastness - Part E02: Colour fastness to sea water
    UNI UNI EN 12088
    2013.04.18 Thermal insulating products for building applications - Determination of long term water absorption by diffusion
    UNI UNI/TS 11325-4
    2013.04.18 Pressure equipment - Putting into service and use of pressure equipment and assemblies - Part 4: Operational methods for the integrity assessment of pressure equipment working under creep conditions related to the assessment procedure of the UNI/TS 11325-2
    UNI UNI CEN/TS 81-76
    2013.04.18 Safety rules for the construction and installation of lifts - Particular applications for passengers and goods passenger lifts - Part 76: Evacuation of disabled persons using lifts
    UNI UNI EN 1603
    2013.04.18 Thermal insulating products for building applications - Determination of dimensional stability under constant normal laboratory conditions (23 °C/ 50 % relative humidity)
    FAA MMEL DA-7X
    2013.04.18 Master Minimum Equipment List Dassault Aviation DA-7X (Falcon 7X) - Revision 6
    UNI UNI EN ISO 105-E04
    2013.04.18 Textiles - Tests for colour fastness - Part E04: Colour fastness to perspiration
    UNI UNI EN 13877-2
    2013.04.18 Concrete pavements - Part 2: Functional requirements for concrete pavements
    UNI EC 1-2013 UNI 11023
    2013.04.18 Self loading mobile mixers - Safety requirements
    ISO DIS 13927
    2013.04.18 Plastics - Simple heat release test using a conical radiant heater and a thermopile detector
    UNI UNI EN 16210
    2013.04.18 Transportation loads - Measurement and evaluation of climatic and other loads - Data acquisition and general requirements for measuring equipment
    UNI UNI EN 13442
    2013.04.18 Wood flooring and wood panelling and cladding - Determination of the resistance to chemical agents
    UNI UNI EN 16291-2
    2013.04.18 Glass packaging - Screw finishes for pressure capsules - Part 2: One way glass MCA 2 finish
    UNI UNI EN 16293
    2013.04.18 Packaging - Glass Packaging - Deep BVS finishes for still wines
    UNI UNI EN ISO 14910-2
    2013.04.18 Plastics - Thermoplastic polyester/ester and polyether/ester elastomers for moulding and extrusion - Part 2: Preparation of test specimens and determination of properties
    UNI UNI EN 505
    2013.04.18 Roofing products from metal sheet - Specification for fully supported roofing products of steel sheet
    UNI UNI EN ISO 20795-2
    2013.04.18 Dentistry - Base polymers - Part 2: Orthodontic base polymers
    UNI UNI EN 16139
    2013.04.18 Furniture - Strength, durability and safety - Requirements for non-domestic seating
    UNI UNI EN 14678-1
    2013.04.18 LPG equipment and accessories - Construction and performance of LPG equipment for automotive filling stations - Part 1: Dispensers
    UNI UNI EN 12086
    2013.04.18 Thermal insulating products for building applications - Determination of water vapour transmission properties
    UNI UNI EN ISO 23611-5
    2013.04.18 Soil quality - Sampling of soil invertebrates - Part 5: Sampling and extraction of soil macro-invertebrates
    UNI UNI EN 14066
    2013.04.18 Natural stone test methods - Determination of resistance to ageing by thermal shock
    UNI UNI 11488
    2013.04.18 Cultural heritage - Guide lines for the classification, the identification of the composition and the evaluation of the performance characteristics of the restoration mortars
    UNI UNI EN 71-4
    2013.04.18 Safety of toys - Part 4: Experimental sets for chemistry and related activities
    UNI UNI EN ISO 105-E01
    2013.04.18 Textiles - Tests for colour fastness - Part E01: Colour fastness to water
    UNI UNI EN ISO 15527
    2013.04.18 Plastics - Compression-moulded sheets of polyethylene (PE-UHMW, PE-HD) - Requirements and test methods
    UNI UNI EN ISO 11890-2
    2013.04.18 Paints and varnishes - Determination of volatile organic compound (VOC) content - Part 2: Gas-chromatographic method
    UNI UNI EN 16289
    2013.04.18 Glass packaging - Screw finishes for pressure capsules - MCA 7,5 RF finish
    UKCAA FORM SRG 1136
    2013.04.18 Application To Change The Competent Authority For Issue Of Pilot’s Licence Or Associated Ratings Or Certificate To The United ------- From Another EASA Member State - Issue 8
    UNI UNI/TS 11487
    2013.04.18 Heat pump geothermal systems - Installation requirements for direct expansion systems
    UNI UNI CEN/TR 15993
    2013.04.18 Automotive fuels - Ethanol (E85) automotive fuel - Background to the parameters required and their respective limits and determination
    UNI UNI EN 12159
    2013.04.18 Builders hoists for persons and materials with vertically guided cages
    ISO DIS 3385.2
    2013.04.18 Flexible cellular polymeric materials - Determination of fatigue by constant-load pounding
    ISO DIS 16571.2
    2013.04.18 Systems for evacuation of plume generated by medical devices
    DODD 5505.08
    2013.04.17 Military Criminal Investigative Organizations (MCIO) and Other DoD Law Enforcement Organizations Investigations of Adult, Private, Consensual ---ual Misconduct
    BSI 13/30282961 DC
    2013.04.17 Draft BS CISPR 15 ED 8.0/A1 Limits and methods of measurement of radio disturbance characteristics of electrical lighting and similar equipment - Amendment 1
    ASHRAE 90.1-2010 SI ERTA
    2013.04.17 Energy Standard for Buildings Except Low-Rise Residential Buildings
    ASHRAE 62.2 ERTA
    2013.04.17 Ventilation and Acceptable Indoor Air Quality in Low-Rise Residential Buildings
    ASHRAE 90.1-2010 I-P ERTA
    EASA AD 2006-0265-CN
    2013.04.17 ATA 34 - Cancelled: Navigation Systems – Mode S And C Transponders – Check
    BSI 13/30283149 DC
    2013.04.17 Draft BS EN 9104-002 Requirements for Oversight of Aerospace Quality Management System Registration/Certification Programs
    EASA SIB 2011-15R1
    2013.04.17 Safety Information Bulletin - Mode S And Mode C Transponder Systems: Ground Testing
    BSI BIP 0134
    2013.04.17 IT Service Management Collection - To Purchase Call 1-800-854-7179 USA/Canada or 303-397-7956 Worldwide
    FAA AD 2013-03-22
    2013.04.17 To Prevent Inadequate Fire Protection In The Cargo Compartment And Consequent Uncontrolled Fire
    BSI 13/30271797 DC
    2013.04.17 Draft BS EN 61534-1+A1 Powertrack systems Part 1: General requirements Amendment 1
    BSI 13/30277795 DC
    2013.04.17 Draft BS EN ISO 17892-1 Geotechnical investigation and testing - Laboratory testing of soil Part 1: Determination of water content (conversion of CEN ISO TS 17892-1 into EN)
    UKCAA SN-2013/008
    2013.04.17 Safety Notice - Minimising The Use Of Memory Buffers In Recording Hardware To Reduce The Possibility Of Data Loss
    FAA AD 2013-04-14
    2013.04.17 To Detect And Prevent Unwanted Movement Of A Pilot Or Co-Pilot Seat In The Horizontal Direction
    internationalstandard2012@gmail.com
  1. International Codes and Standards
    By bzbipin in forum Instrumentation & Control
    Last Post: 05-14-2016, 10:00 PM
  2. International Environmental Standards Handbook
    By sasirkumar in forum Safety And Environment
    Last Post: 09-05-2011, 12:36 PM
  3. International IEC Standards in relation with Profibus and Profinet
    By amshah in forum Instrumentation & Control
    Last Post: 07-26-2010, 01:02 PM
  4. International Engineering Standards
    By DORIO in forum Self Improvement
    Last Post: 02-03-2009, 11:30 PM
