hi
im asking how to simulate for preloop from the field to Process Interface Bldg. (PIB) or DCS this instrument : the tools we been use was Hart Communicator 375,LC 100 Martel , Druck 300 DPI603 , Ametek 7975 Hand pump , megger , TK3 and can you give a drawing the typical setup of each instrument to calibrator to simulate the preloop ?im appreciate those who will help me. and how to use the calibrator to simulate the instrument
H2s gas detector
combustible Gas Detector
Corrission XMTR and Access Fitting CM
BEACONS
HORN
TRANSMITTER HART / ANALOG
Corrission Transmitter
DP Flow Transmitter w/ ventury
Rotameter Transmitter
Analyzer Indicator Transmitter
Agar Level Transmitter
Vibration Transmitter
Intensity Current Transmitter
Magnetic Flow Meter
Remote Level Indicator
Remote Temperture Indicactor
Temperature Indicator Transmitter
DP Level Indicator Transmitter
TRANSMITTER FIELDBUS
Corrission Transmitter Fieldbus
DP Flow Transmitter w/ ventury Fieldbus
Rotameter Transmitter Fieldbus
DP Level Indicator Transmitter Fieldbus
Guide Wave Radar Level Transmitter Fieldbus
Analyzer Indicator Transmitter Fieldbus
Agar Level Transmitter Fieldbus
Vibration Transmitter Fieldbus - FFVMS Trend master 2000/ Velocity Seismo Probe
Magnetic Flow Meter Fieldbus
Remote Level Indicator Fieldbus
Remote Temperture Indicactor Fieldbus
Temperature Indicator Transmitter Fieldbus
Termocouple Temperature Transmitter
RTD Temperature Transmitter
CONTROL VALVE
ON OFF Deluge Valve
Level control valve Fieldbus
Hand Control Valve Fieldbus
Temperature Control valve Fieldbus
Pressure Control Valve Fieldbus
Level Control Valve Fieldbus
MOV FF
AOV FF
SWITCH
Pressure Switch
Level Switch
Temperature switch
Flow Switch
Pig tail
