Thread: Temperature due to Heat Flux
  1. Unhappy Temperature due to Heat Flux
    Hi all,
    I was wondering if someone could help me with the following issue:
    I have a jet fire from a vessel, which applies a heat flux of 15 kW/m2 on a vessel say 10 m away
    How can I calculate the increase in temperature?
    Is it through Q = mc Delta T
    If it is what would I use as m and c?
    Many thanks
    J
  3. Re: Temperature due to Heat Flux
    use equation
    T = [(heat flux/stefan boltzmann constant-5.67x 10^-11)+(Temp. of surrounding)^4]
  5. Re: Temperature due to Heat Flux
  1. Compact plate heat exchangers used for refinery heat recovery
    By Freeman in forum Petroleum Refining
    Last Post: 05-06-2018, 02:50 PM
  2. Replies: 0
    Last Post: 06-25-2014, 06:11 PM
  3. Steam trap type in heat tracing of heat sensitive material
    By gmbobs in forum General Engineering
    Last Post: 05-28-2013, 02:15 PM
  4. need flux expert
    By chem_ing in forum General Engineering
    Last Post: 05-04-2010, 01:50 PM
  5. Heat Exchanger Design & Log Mean Temperature Difference
    By Freeman in forum Oil And Gas Process
    Last Post: 01-31-2009, 02:26 PM
