Results 1 to 7 of 7
Thread: Numerical Vs. Analytical Aquifer
  1. Numerical Vs. Analytical Aquifer
    Hi guys.
    Can someone explain me where I should use Analytical aquifer and where I have to use Numerical aquifer in reservoir simulation.
    I would like also know about the main advantages of each method.
  2. Re: Numerical Vs. Analytical Aquifer
    I have a PPT about Aquifer ,but It is written in Chinese.
  4. Re: Numerical Vs. Analytical Aquifer
    Quote Originally Posted by loveboyzmj View Post
    Loveboyzmj
    Can I have your PPT file. Unfortunately no one answers me.
    Thank you.
  5. Talking Re: Numerical Vs. Analytical Aquifer
    My e-mail address is loveboyzmj@sina.com.
    Please email me, then I send you the PPT file.
    Hey arm,
    This information will be useful. Best regards.
    Attached Files Attached Files
  8. Re: Numerical Vs. Analytical Aquifer
    Nice topic for discussion))
  9. Re: Numerical Vs. Analytical Aquifer
    Very helpful threat..thanks.
    I was facing a model case which (analyzed) water is coming through a fault between active grids above OWC.
    I applied Carter-Tracy for this connection, and for the normal (below OWC) with Fetkovich. This way consume less time than applying 2 same spesification, in my case Fetkovich-Fetkovich need 4 times longer runtime than CT-Fetkovich.
    However, i quote in the page 332 "Fetkovich and Carter-Tracy aquifers cannot be used in the same run". I have no problem running this, it's even faster..
    The reason i came here, is to ask, weather is it possible to put a Numerical Aquifer to represent water from -----s? And if it can, do you think it can reduce the runtime? I'm thinking it's about to give worse problem..since, i quote from the post "that aquifers connected to cells above the OWC will flow into the oil zone. In numerical aquifers this takes place because the interblock mobility is taken from the upstream (aquifer) cell, not the downstream cell in which the water relative permeability may be zero. Analytical aquifer flow is independent of relative
    permeability."
    Just sharing my experience
  1. Modeling Aquifer in Eclipse
    By ibtisam01 in forum Reservoir
    Last Post: 06-20-2014, 11:53 PM
  2. Unsteady State Aquifer Representations
    By ameer in forum Reservoir
    Last Post: 12-19-2012, 10:36 PM
  3. gas reservoir with bottom aquifer-help needed
    By tinni in forum Reservoir
    Last Post: 07-04-2011, 05:08 PM
  4. Weak Aquifer - ECLIPSE
    By 06pg22 in forum Reservoir
    Last Post: 03-18-2011, 11:33 PM
