Page 1 of 2 1 2 LastLast
Results 1 to 12 of 23
Thread: Download Electrical Engineering Program (Excel Base)
  1. Download Electrical Engineering Program (Excel Base)
    Hi ,
    I am sharing some useful Excel base Program of Electrical Engineering.
    Cable Designing Program
    * Calculate Voltage drop of Cable.
    * Calculate Size of Cable.
    * Calculate Current Capacity of Cable.
    Conduit Size Selection Program
    * Calculate Size of Conduit for LT Cable/CAT-5 Cable/Fiber Optical Cable.
    Selection of MCCB,ELCB For Main /Branch Circuit.
    * Calculate Size and Type of Main MCCB/RCCB/ELCB for Continious and Non Continious Load
    * Calculate Sensitivity of MCCB/RCCB/ELCB.
    * Calculate Size and Type of Sub Circuit MCCB/MCB for Continious and Non Continious Load
    * Calculate Total Load .
    * Calculate Main and Branch Circuit Current.
    Selection of Fuses
    * Calculate Size of Fuse for Electrical Circuit.
    Size of Capacitor For Power Factor Improvements
    * Calculate Size of Capacitor for Power Factor Improvements.
    * Calculate Annual Saving by selection of Capacitor.
    * Calculate Active and Reactive Power.
    Short Circuit Current Calculation at Various Point of Electrical Curcuits(Isc).
    * Calculate Short Circuit Current at Substation.
    * Calculate Short Circuit Current at Distribution point.
    * Calculate Short Circuit Current at Transformer.
    * Calculate Short Circuit Current at Main Panel.
    * Calculate Short Circuit Current at Sub Distribution Board.
    Circuit Breaker Tripping Settings.
    * Calculate Tripping Setting of Circuit Breaker.
    Motor Specifications
    * Calculate Various Specification of Motor.
    Calculate Home Electrical Load & Electrical Bill.
    * Calculate Electrical Bill of Home
    * Calculate Size of MCCB/MCB for Domestic Load
    * Calculate Electrical Load of Home.
    Calculate Insulation Resistance Value and PI value
    * Calculate minimum Insulation Resistance Value for Various Electrical Equipments.
    * Calculate IR Value of Electrical Equipments.
    * Graph of IR Value
    * Calculate Polarization Index Value with Graph
    * Calculate Earth Resistivity.
    Calculate Electrical Load and Energy Consumption of Panel.
    * Calculate Continuous and non Continuous Electrical Load of Panel.
    * Calculate total Energy Consumption(KWH) in Daily/Monthly of Panel.
    * Calculate Size of MCB of each branch circuit of Panel.
    * Calculate Voltage / Voltage Difference of Each Phase
    * Calculate Unbalanced Load in Neutral Wire.
    * Calculate Expected Temperature rise in Each Phase.
    * Calculate Load in Each Phase.
    * Calculate Starting/Full Load/Continuous/Non Continuous Load
    * Calculate Size/Type/Tripping setting of Main MCCB.
    Calculate Size of Battery Bank and Inverter.
    * Calculate Total Demand Load
    * Calculate Size of Battery Bank in Amp.Hr.
    * Select Type of Connection of Batteries in Battery Bank
    * Select Rating of Each Battery in Battery Bank
    * Calculate Size of Inverter
    Calculate Size of Solar Panel / Battery Bank / Inverter.
    * Calculate Size of Solar Panel.
    * Select Type of Connection of Solar Panel.
    * Select Rating of Each Solar Panel.
    * Calculate Energy from Solar Panel as per Daily Sun lights.
    * Calculate Size Battery Bank.
    * Select Type of connection of Batteries in Battery Bank
    * Calculate size of Inverter
    Calculate No of Lighting Fittings and Lumen Output.
    * Calculate Total Lumen Output for particular Area.
    * Calculate Total No of Lighting Lamps.
    * Calculate Total No of Lighting Fixtures.
    * Calculate No of Fittings along with the Length and Width of Room.
    Calculate Bus Bar Size and Voltage Drop.
    * Calculate Voltage Drop for Bus Bar.
    * Select Size of Bus Bar for particular Load.
    * Enter Your Sub Panel Details like Load,Line Length.
    Design of Earthing Mat for Sub-Station:
    * Program is design as per ANSI/IEEE 80-1986 Code.
    * Calculate Step Potential of Switch yard.
    * Calculate Touch Potential of Switch yard.
    * Calculate Total Length of Earthing Mat Conductor.
    * Calculate Size of Earthing Mat Conductor.
    * Calculate Total No of Earthing Rods.
    Calculate Touch Voltage and Ground Current.
    * Calculate Resistance of Each Phase.
    * Calculate Resistance of neutral/Ground.
    * Calculate Neutral Current and Load.
    * Calculate Touch Voltage for Metal part to Earth.
    * Calculate Body Resistance and Body Current.
    Download Links:
    [link Point to another website Only the registered members can access] OR
    good work. thanks
    Nov 2009
    All over EGPET
    Blog Entries
    1
    Files not available, Kindly share again. Thanks in advance.
    Thanks very useful information for technical professional
  7. Thanks for the useful EXcel format.
  9. #6
    Sep 2010
    I'm from Brazil, I live at Campinas city in the Sao Paulo state
    thanks a lot. very usefull
  10. hey dude am unable to download the file pls. could you guide me r else send it to tulajappa@gmail.com. thank you for knowing new things from you.
  11. #8
    Cool down link is not working
    Hi Sir, this is raju.. i am unable to download your link, can you please send the file to my mail (cagraju@yahoo.com),
  12. #9
    Hi
    i am not able to download the file , please help me ( my mail id vishy_vandu@yahoo.com)
    thansks
  13. thank you very very thanks
  14. #11
    please send me the file
    sir, please send me the file, here is my email add, nyah1829@yahoo.com. thank you very much.
  16. i couldnt find anything
    can u send it to me (( Mohd.bastaki@hotmail.com ))
    By jiguparmar in forum Electrical & Power Engineering
    Last Post: 11-02-2016, 03:01 PM
  2. Anchor Bolt Excel Program
    By rendevouspoo in forum Civil & Structural Engineering
    Last Post: 12-04-2013, 09:51 AM
  3. Tubmov Excel Program -
    By hehehehehehehe in forum Drilling And Workover
    Last Post: 05-18-2013, 08:04 PM
