Strange,
I think You might lose something of the step, just folow the step, and I never fail to instal, some condition I guess is
1. Do you copy-paste of LM32 files ?
2. Does your computer is 64bits ?
3. or maybe you install software on company computer ?
Some company computer is restricted for installing other software that is not "on the list" from the company, in that case you can not install it. I've ever found one computer from "Shell Global solution Company" that is unable to change setting nor install software.
Just to remind again about the steps
INSTALLATION PROCEDURE
1. Make sure your computer is 32bit windows, otherwise, skip to step "note #3" first.
2. downloaded file is on iso format, so burn it on DVD, (or you can use virtual CD to read it)
3. disable connection to internet
4. disable antivirus and other firewall software on your computer
5. Run etap installer
6. select install + license manager, just follow the instruction.
Note : For Win-7 (and maybe Vista, but I never use vista) will show up UAC, just click/select enable to install
7. When finish installation, dont run the software.
8. Open folder LMSETUP\SYSTEM32\DRIVERS on etap DVD
9. copy all files in the LMSETUP\SYSTEM32\DRIVERS ----- to ------ C:\Windows\System32\Drivers\
10. Extract ETAP ******** (peta_6.zip) to ETAP 700 folder
11. for vista & win-7 user, set compatibiliy to to "windows xp, SP 3" and "always run on administrator previliege" ,
12. then run file " etap6.exe " this is the software to bypass license.
this file is under DOS file, so you will see DOS application run.
Note : Why extract to Etap-7 folder, because I've ever fail to run it when extract outside etap 700 folder.
13. After finish install ********, then Reboot your computer/laptop.
14. Enable again your antivirus
15. for windows vista and above (incl win-7) Set compatibility of etaps.exe to "windows xp, SP 3" and "always run on administrator previliege"
16. Run ETAp 7 application.
17. Will show up window for license , click OK, then software will ask for activation serial
Enter Activation serial : 9dp8kD6Ncc#Y8r5FBL+QEn3DHqDBKR<7Nc4/
18. Try to run and open example project, then double click on certain equipment.
19. try to change the parameter, and save. If it is OK, then the software is working well now, ready to sail
20. if you cant edit the parameter, I do not know the clue yet, but I try this way to solve it.
a. ==> try to install on other computer with the same step as above, and follow until step #19,
b. if it is working well on that other computer (other wise you have to install again on other computer again)
c. then copy the folder c://etap 7.0.0 from that working etap computer to the computer that has the
problem with changing the specification. It use to be working fine.
==> this sometimes happening on computer
- that has coorporate antivirus,
- coorporate anti installing software,
- or other computer that has installed software to prevent install virtual key, virtual port, etc
21. Then enjoy using ETAP 7
Note :
1. Installation on Win-XP and Win-7 or maybe Win-Vista are all the same except the UAC enabling step
on Win-7 and Vista ==> step 11 & 15.
2. People always forget to do the step number 8 and 9. If you forget, then the licence would not be found.
3. If you are diligent to follow each step and nothing skipped, but the computer always asking for license,
then your computer is 64bit. In this case, try to install vmware (or other virtual machine software)
software at your computer, install windows 32bit as client computer on vmware, then install this etap
on the client computer 32bit. I have tried this step several time and success
Hope this help you.
