Results 1 to 12 of 48
Thread: Tuning EOS parameters
    Take a look at this also
    Now this paper deals with QC of the data BEFORE going to the tuning process
    This is something that Prof. Whitson spends some time explaining in the lectures.
    This one is also on the NET. Use GOOGLE.
    New strategic method to tune equation-of-state to match experimental data for compositional simulation
    by Al-Meshari, Ali Abdallah, Ph.D., TEXAS A&M UNIVERSITY, 2004, 248 pages; 3156484
    Abstract:
    Since the plus fraction of reservoir fluids has some uncertainty in its molecular weight and critical properties, equation-of-state, EOS, are generally not predictive without tuning its parameters to match experimental data. Tuning of the EOS is found to be the best method for improving the predictions of compositional reservoir simulators.
    The proposed strategy for tuning EOS consists of seven steps: (1)?split the laboratory plus fraction to single carbon number groups, SCN, usually up to SCN 44; the last component will be C45+ , (2)?use set of correlations to calculate the critical properties and acentric factor for each SCN group, (3)?match the saturation pressure at reservoir temperature by altering the measured value of the molecular weight of the plus fraction using the extended composition, (4)?group SCN groups to multiple carbon number groups, MCN, (5)?assign critical properties and acentric factor for each MCN group, (6)?rematch the saturation pressure at reservoir temperature using the grouped composition, and (7)?match the volumetric data by regressing on volume shift parameters of all components in grouped composition.
    This research shows an accurate method to split the plus fraction to SCN groups. The most accurate set of correlations to calculate the critical properties and acentric factor for each SCN group that will result in a small adjustment for the molecular weight of the plus fraction when saturation pressure is matched using the extended composition. The proposed strategy groups the extended composition to eight pseudocomponents. The binary interaction coefficients between hydrocarbons and between hydrocarbons and non-hydrocarbons are set to zero which dramatically reduces the simulation time.
    The strategy proposed in this research for tuning EOS to match experimental data has been tested for a wide range of C7+ mole% (4-25) which covers gas condensate and volatile oil samples. Also, using this strategy to tune EOS at reservoir temperature will accurately predict the fluid properties at separator conditions and saturation pressures at different temperatures.
    The scope of this research is to come up with an accurate and systematic technique for tuning an EOS for use in compositional simulation.
    —Big Oil Executive
  1. use of parameters obtain by well testing
    By Abu Saleh in forum Forums development
    Last Post: 08-31-2014, 07:17 PM
  2. Peng rob eos binary parameters
    By mariorossi1983 in forum General Engineering
    Last Post: 05-22-2014, 02:12 PM
  3. Need help for averaging drilling parameters and others question.
    By zealousman in forum Drilling And Workover
    Last Post: 07-23-2013, 08:20 PM
  4. Electric Submersible Pump (ESP) parameters
    By ali in forum Oil And Gas Production
    Last Post: 08-29-2011, 12:16 PM
  5. Thomeer parameters fitting software
    By zharas in forum Geology & Exploration
    Last Post: 02-16-2010, 06:05 PM
