Results 1 to 6 of 6
Thread: foam problem at production separator
    how we can overcome foam problem in production separator because this problem cause activation of H.H.L switch many time
    A very classical issue. Use anti foam.
    In oil fields, separators are used to separate oil and gas contained in the crude oil pumped
    from the wells before processing. Although there are many factors influencing the
    performance of these separators, one of the crucial problems is the formation of foam due
    to the impurities present in the crude. Another operating problem is carry-over, which occurs
    when free liquid escapes with the gas phase. Of the several methods used to control foam,
    chemical control by use of antifoam agents is very important.
    You keep ph under 8.
  7. Mechanical foam breakers
    If it can't be managed with chemicals or by changing operating levels, you can retrofit a mechanical foam breaker like those in the attached leaflet.
    Attached Files Attached Files
  9. #6
    1-using anti foam chemicals
    2-using additional internal devices
    3- increasing pressure setpoint
  1. Article: Production separator cleaning
    By Mr Chem Eng in forum Home Articles
    Last Post: 08-25-2013, 01:37 AM
  2. Production separator cleaning
    By Mr Chem Eng in forum Oil And Gas Production
    Last Post: 07-25-2013, 06:52 PM
  3. Article: Production Study Problem
    By Petengineer in forum Home Articles
    Last Post: 10-27-2011, 11:36 AM
  4. Production Study Problem
    By Petengineer in forum Oil And Gas Production
    Last Post: 10-11-2011, 02:07 AM
