INPRO has been designed in conjunction with oil companies and contractors to assist engineers in the feasibility and conceptual design process of an oil/gas facility. Its objectives are to provide accurate front-end weights and dimensions for all key process equipment, and to allow rapid optimisation of design options.
Industry-standard technical calculations
-Rapid check of detailed design calculations
-Cost optimisation facility
-Links into QUE$TOR™ (The world's leading E&P project cost evaluation software)
-Supplied with detailed user manual -Can run in any standard units
INPRO contains a set of individual calculation modules, including but not limited to:
-Separators: Sizing routines for 2 phase or 3 phase vertical or horizontal vessels, allowing full specification of mechanical details.
-Flare & Vent Systems: Selects tip type. From gas data and environmental conditions determines all aspects of system design.
Gas Properties: Estimates physical and combustion properties of a gas mixture at a specified temperature and pressure.
Heat Exchangers: Estimates sizes and weights for either shell and tube or air-cooled heat exchangers.
Compressors: Sizes overall compression package showing each stage of compression and the required suction scrubbers and after-coolers.
Pumps: Incorporates pipeline sizing routines to determine required pump parameters, such as pressure drops, power, dimensions and weights.
Pipelines: Line sizing for gas and liquids lines. Includes cool down curves and pipeline topography definition.
Gas Dehydration: Estimates hydrate formation temperature. Allows sizing of glycol contactor and regeneration packages. Has options for structured, random and trayed contactors.
APPEAL TO KIND BROTHERS WHO HAVE IT TO SHARE AND BENEFIT THIS FORUM
WARM REGARDS
