Results 1 to 1 of 1
Thread: EO double block and bleed valves and pipe class question on the P&ID
    EO feed(OP=12 barg, OT= -25 C) to the reactor (OP=12 barg, OT=215 C),and feed line seems climb upward to the Reactor top.
    I am just curious why this liquid fluild piping instead of gas fluid go upward.
    Morever, in our process, we don’t use a triconics interlock system with at least 2 - double block and bleed valves to assure isolation of the EO. We use 4 valves.
    Could any one professional kindly explain to me what is different in this two chooses?
    And, the other piping class question, genarrly the pipe class with more pound limts will have
    Higher design temperature limt also?
    Thank you very much for your kindly help.
    Attached Files Attached Files
  1. Pipe Class Component Software (PCC)
    By unlock in forum Engineering Spreadsheets & Presentations
    Last Post: 02-05-2019, 05:45 PM
  2. On/off valves leakage class standard
    By aidini in forum Instrumentation & Control
    Last Post: 07-04-2018, 12:28 PM
  3. Replies: 0
    Last Post: 04-18-2014, 03:30 PM
  4. Replies: 7
    Last Post: 03-30-2014, 01:45 AM
