is simple, using a drilled plate, and place it between the nut and the body of the flange. That plate buckling work will be welded to a base plate, and will be on this last plate where you do the fixed point. To prevent the bucking on the plate, you can use vertical plates between the two plates for prevent it.
You must not forget the sure need to include longer bolts for the flange.
