Results 1 to 9 of 9
Thread: Pipe stress Analysis
    WHAT IS STRESS ANALYSIS?
    Piping Stress analysis is a term applied to calculations, which address the static and dynamic loading
    resulting from the effects of gravity, temperature changes, internal and external pressures, changes in fluid
    flow rate and seismic activity. Codes and standards establish the minimum requirements of stress
    analysis.
    PURPOSE OF PIPING STRESS ANALYSIS
    Purpose of piping stress analysis is to ensure:
    Safety of piping and piping components.
    Safety of connected equipment and supporting structure.
    Piping deflections are within the limits.
    HOW PIPING AND COMPONENTS FAIL (MODES OF FAILURES)
    There are various failure modes, which could affect a piping system. The piping engineers can provide protection against some
    of these failure modes by performing stress analysis according to piping codes.
    FAILURE BY GERNRAL YIELDING: Failure is due to excessive plastic deformation.
    Yielding at Sub Elevated temperature: Body undergoes plastic deformation under slip action
    of grains.
    Yielding at Elevated temperature: After slippage, material re-crystallizes and hence yielding
    continues without increasing load. This phenomenon is known as creep.
    FAILURE BY FRACTURE: Body fails without undergoing yielding.
    Brittle fracture: Occurs in brittle materials.
    Fatigue: Due to cyclic loading initially a small ----- is developed which grows after each cycle and
    results in sudden failure.
    WHEN PIPING AND COMPONENTS FAIL (THEORIES OF FAILURE)
    Various theories of failure have been proposed, their purpose being to establish the point at
    which failure will occur under any type of combined loading.
    The failure theories most commonly used in describing the strength of piping systems are:
    Maximum principal stress theory
    This theory states that yielding in a piping component occurs when the magnitude of any of the
    three mutually perpendicular principle stresses exceeds the yield point strength of the material.
    Maximum shear stress theory
    This theory states that failure of a piping component occurs when the maximum shear stress
    exceeds the shear stress at the yield point in a tensile test.
    In the tensile test, at yield, S
    1=Sy (yield stress), S2=S3=0.So yielding in the components occurs
    when
    Maximum Shear stress =
    τmax=S1-S2 / 2=Sy / 2
    The maximum principal stress theory forms the basis for piping systems governed by ASME B31.3.
    Note: maximum or minimum normal stress is called principal stress.
    STRESS CATEGORIES
    The major stress categories are primary, Secondary and peak.
    PRIMARY STRESSES:
    These are developed by the imposed loading and are necessary to satisfy the equilibrium between external
    and internal forces and moments of the piping system.
    Primary stresses are not self-limiting.
    SECONDARY STRESSES:
    These are developed by the constraint of displacements of a structure. These displacements can be caused
    either by thermal expansion or by outwardly imposed restraint and anchor point movements.
    Secondary
    stresses are self-limiting
    PEAK STRESSES:
    Unlike loading condition of secondary stress which cause distortion, peak stresses cause no significant
    distortion. Peak stresses are the highest stresses in the region under consideration and are responsible for
    causing fatigue failure.
    CLASSCIFICATION OF LOADS
    Primary loads:
    These can be divided into two categories based on the duration of loading.
    Sustained loads
    These loads are expected to be present through out the plant operation. e,g. pressure and weight.
    Occasional loads.
    These loads are present at infrequent intervals during plant operation. e,g. earthquake, wind, etc.
    Expansion loads:
    These are loads due to displacements of piping. e,g .thermal expansion, seismic anchor movements, and
    building settlement.
    REQUIRMENTS OF ASME B31.3 (PROCESS PIPING CODE)
    This code governs all piping within the property limits of facilities engaged in the processing or handling
    of chemical, petroleum or related products. Examples are a chemical plant, petroleum refinery, loading
    terminal, natural gas processing plant, bulk plant, compounding plant and tank farm.
    The loadings required to be considered are pressure, weight (live and dead loads), impact, wind,
    earthquake-induced horizontal forces, vibration discharge reactions, thermal expansion and contraction,
    temperature gradients, anchor movements.
    The governing equations are as follows:
    1.Stresses due to sustained loads.
    SL < Sh
    SL = (PD/4t) + Sb
    Sh = Basic allowable stress at maximum metal temperature.
    The thickness of the pipe used in calculating SL shall be the nominal thickness minus mechanical,
    corrosion, and erosion allowance.
    2.Stresses due to occasional loads.
    The sum of the longitudinal loads due pressure, weight and other sustained loads and of stresses produced
    by occasional loads such as earthquake or wind shall not exceed 1.33Sh.
    3.Stress range due to expansion loads.
    The displacement stress range SE shall not exceed SA:
    SE < SA
    WHERE
    SE = (Sb
    2
    + 4St
    2
    ) ½
    Sb = resultant bending stress,psi
    = [(IiMi)2 + (IoMo)2] / Z
    Mi = in-plane bending moment, in.lb
    Mo = out-plane bending moment, in.lb
    Ii = in- plane stress intensification factor obtained from appendix of B31.3
    Io = out- plane stress intensification factor obtained from appendix of B31.3
    St = Torsional stress ,psi
    = Mt / (2Z)
    Mt = Torsional moment, in.lb
    SA = Allowable displacement stress range:
    (Allowable stress) cold = Sc = (2 / 3) Syc ⇒ Syc = (3/2)Sc
    (Allowable stress) hot = Sh = (2 / 3) Syh ⇒ Syh = (3/2) Sh
    Syc = yield point stress at cold temperature
    Syh = yield point stress at hot temperature
    Allowable stress =Syc + Syh
    =3/2 (Sc + Sh )
    = 1.5 (Sc + Sh )
    = 1.25(Sc + Sh )---- after dividing with F.O.S
    Final allowable stress = [(1.25(Sc + Sh) – SL]
    SA = f [(1.25(Sc + Sh) – SL]
    Sc = basic allowable stress at minimum metal temperature
    f = stress range reduction factor from table 302.2.5 of B31.3
  2. thnx @ Cobraaa ..... that was answer in detail .............. Sir can i find book on "Pipe Stress Engg " by L.C Peng.............??
  1. Riser Stress Analysis-Pipe-in-Pipe
    By quynhchau84 in forum Pipeline And Fluid Flow
    Last Post: 07-17-2013, 04:36 AM
  2. Pipe stress Analysis
    By gnuisu in forum Civil & Structural Engineering
    Last Post: 06-13-2013, 09:51 AM
  3. Stress analysis of pipe
    By HUGH12345 in forum Pipeline And Fluid Flow
    Last Post: 12-26-2010, 05:39 PM
