Thread: Wellwise allocation based on total field rate
  1. Wellwise allocation based on total field rate
    Dear All,
    I am working on the field that is producing with five wells.
    The total field production is obtained from the volumetric meter.
    At any given point of time, only one well can be passed through test separator to know its oil rate, GOR and Water Cut.
    Based on this, How is it possible to allocate the total field production of oil, gas and water for each of the wells when that well is not passed through test separator?
    Is there any method to allocate the oil,gas and water production based on the Flowing Bottom Hole Pressure for the wells?
  3. Dear ;
    You Can Estimate and Calculate The Liquid Rate For Each Well With Out Test Seperator By This Correlation , You Need Input Data WHP, Choke Size and GLR.
  5. my recommendation is to test well by well, and you can reach a total productivity for each well, and calculate in excel a percentage strengh on each well and sum that incredible % to total production form field, according to, for example WHP, or another parameter, than You reach a sum up to number of producting well at given moment, day mounth week,
    regards
  1. Back allocation
    By Dunfy in forum Reservoir
    Last Post: 05-19-2013, 10:23 AM
  2. Article: Total field optimization, Need Suggestions!
    By cybermoj in forum Home Articles
    Last Post: 04-03-2012, 12:15 AM
  3. Total field optimization, Need Suggestions!
    By cybermoj in forum Reservoir
    Last Post: 03-31-2012, 10:58 AM
  4. Minimum Economic Production rate estimation for a field
    By 06pg22 in forum Oil And Gas Production
    Last Post: 09-05-2010, 03:59 AM
