Results 1 to 6 of 6
Thread: how i can Calculating the viscosity blending index
    how i can Calculating the viscosity blending index of a liquid consisting of two
    or more liquids having different viscosities
  3. Bro Ali,
    You can get it by applying mixing rule which is you need to the viscosity of pure component fraction and sum all those to get the mixture viscosity. Anyone please comment if there is any mistakes.
  5. Please refer to the following link:
    I hope it answers your question.
  6. Viscosity Blending Index calculation
    Viscosity blending equations
    Calculating the viscosity blending index of a liquid consisting of two or more liquids having different viscosities is a two step procedure. The first step involves calculation of the Viscosity Blending Index (VBI) of each component of the blend using the following equation (known as a Refutas equation):
    (1) VBI = 14.534 × ln[ln(v + 0.8)] + 10.975
    where v is the viscosity in centistokes and ln is the natural logarithm (Loge).
    The second step involves using this equation:
    (2) VBIBlend = [wA × VBIA] + [wB × VBIB] + ... + [wX × VBIX]
    where w is the weight fraction (i.e., % ÷ 100) of each component of the blend. In using the above blending equation, it is necessary that all viscosities are determined at the same temperature, for example, 100 oC.
    (Reference: Robert E. Maples (2000), Petroleum Refinery Process Economics, 2nd Edition, Pennwell Books, ISBN 0-87814-779-9)
    Once the viscosity blending number of a blend is obtained with equation (2), the viscosity of the blend can be determined by using the invert of equation (1):
    (3) v = ee(VBN - 10.975) ÷ 14.534 - 0.8
    where VBN is the viscosity blending number of the blend and e is the transcendental number 2.71828, also known as Euler's number.
    __________________
  7. Hi, this algorith is very useful but it turns complicated when you try to get a mixture of 3 o more components having final viscosity looking for components fraction.
    There is a software from
    Estimate the volume fractions of four components to make a 380 cSt fueloil by using 5, 600, 150 and 400 cSt compounds
  9. #6
    Nov 2008
    Thessaloniki, Greece
    how i can Calculating the viscosity of mixture ethylene ,oxygen and nitrogen ??? with the above type ?? thanks
  1. Blending Scheme for LPG and Gasoline
    By Ajaykumar in forum Oil And Gas Process
    Last Post: 05-15-2013, 04:23 PM
  2. Motor Gasoline Blending handbook and blending Spreadsheet
    By kimsun74 in forum Petroleum Refining
    Last Post: 09-14-2010, 05:46 PM
  3. Gasoline blending
    By kimsun74 in forum Oil And Gas Production
    Last Post: 08-27-2010, 07:13 AM
  4. calculating the density
    By aj_abdulla in forum Oil And Gas Process
    Last Post: 08-07-2009, 11:39 AM
