only 4 valid editions are missing..
EN 132:1998 Respiratory protective devices - Definitions of terms and pictograms
EN 133:2001 Respiratory protective devices - Classification
EN 134:1998 Respiratory protective devices - Nomenclature of components
EN 135:1998 Respiratory protective devices - List of equivalent terms
EN 136:1998 Respiratory protective devices - Full face masks - Requirements, testing, marking
EN 136:1998/AC:2003 Respiratory protective devices - Full face masks - Requirements, testing, marking
EN 137:2006 Respiratory protective devices - Self-contained open-circuit compressed air breathing apparatus with full face mask - Requirements, testing, marking
EN 138:1994 Respiratory protective devices - Fresh air hose breathing apparatus for use with full face mask, half mask or mouthpiece assembly - Requirements, testing, marking
EN 140:1998 Respiratory protective devices - Half masks and quarter masks - Requirements, testing, marking
EN 140:1998/AC:1999 Respiratory protective devices - Half masks and quarter masks - Requirements, testing, marking - missing
EN 142:2002 Respiratory protective devices - Mouthpiece assemblies - Requirements, testing, marking
EN 143:2000 Respiratory protective devices - Particle filters - Requirements, testing, marking
EN 143:2000/AC:2005 Respiratory protective devices - Particle filters - Requirements, testing, marking
EN 143:2000/A1:2006 Respiratory protective devices - Particle filters - Requirements, testing, marking
EN 144-1:2000 Respiratory protective devices - Gas cylinder valves - Part 1: Thread connections for insert connector
EN 144-1:2000/A1:2003 Respiratory protective devices - Gas cylinder valves - Part 1: Thread connections for insert connector
EN 144-1:2000/A2:2005 Respiratory protective devices - Gas cylinder valves - Part 1: Thread connections for insert connector
EN 144-2:1998 Respiratory protective devices - Gas cylinder valves - Part 2: Outlet connections
EN 144-3:2003 Respiratory protective devices - Gas cylinder valves - Part 3: Outlet connections for diving gases Nitrox and oxygen
EN 144-3:2003/AC:2003 Respiratory protective devices - Gas cylinder valves - Part 3: Outlet connections for diving gases Nitrox and oxygen
EN 145:1997 Respiratory protective devices - Self-contained closed-circuit breathing apparatus compressed oxygen or compressed oxygen-nitrogen type - Requirements, testing, marking
EN 145:1997/A1:2000 Respiratory protective devices - Self-contained closed-circuit breathing apparatus compressed oxygen or compressed oxygen-nitrogen type - Requirements, testing, marking
EN 148-1:1999 Respiratory protective devices - Threads for facepieces - Part 1: Standard thread connection
EN 148-2:1999 Respiratory protective devices - Threads for facepieces - Part 2: Centre thread connection
EN 148-3:1999 Respiratory protective devices - Threads for facepieces - Part 3: Tread connection M 45 x 3
EN 149:2001+A1:2009 Respiratory protective devices - Filtering half masks to protect against particles - Requirements, testing, marking
EN 250:2014 Respiratory equipment - Open-circuit self-contained compressed air diving apparatus - Requirements, testing and marking - missing VE
EN 269:1994 Respiratory protective devices - Powered fresh air hose breathing apparatus incorporating a hood - Requirements, testing, marking
EN 402:2003 Respiratory protective devices - Lung governed demand self-contained open-circuit compressed air breathing apparatus with full face mask or mouthpiece assembly for escape - Requirements, testing, marking
EN 403:2004 Respiratory protective devices for self-rescue - Filtering devices with hood for escape from fire - Requirements, testing, marking
EN 404:2005 Respiratory protective devices for self-rescue - Filter self-rescuer from carbon monoxide with mouthpiece assembly
EN 405:2001+A1:2009 Respiratory protective devices - Valved filtering half masks to protect against gases or gases and particles - Requirements, testing, marking
EN 529:2005 Respiratory protective devices - Recommendations for selection, use, care and maintenance - Guidance document
EN 1146:2005 Respiratory protective devices - Self-contained open-circuit compressed air breathing apparatus incorporating a hood for escape - Requirements, testing, marking
EN 1827:1999+A1:2009 Respiratory protective devices - Half masks without inhalation valves and with separable filters to protect against gases or gases and particles or particles only - Requirements, testing, marking
EN 12021:2014 Respiratory equipment - Compressed gases for breathing apparatus - missing VE
EN 12083:1998 Respiratory protective devices - Filters with breathing hoses, (Non-mask mounted filters) - Particle filters, gas filters, and combined filters - Requirements, testing, marking
EN 12083:1998/AC:2000 Respiratory protective devices - Filters with breathing hoses, (Non-mask mounted filters) - Particle filters, gas filters, and combined filters - Requirements, testing, marking
EN 12941:1998 Respiratory protective devices - Powered filtering devices incorporating a helmet or a hood - Requirements, testing, marking
EN 12941:1998/A2:2008 Respiratory protective devices - Powered filtering devices incorporating a helmet or a hood - Requirements, testing, marking
EN 12942:1998 Respiratory protective devices - Power assisted filtering devices incorporating full face masks, half masks or quarter masks - Requirements, testing, marking
EN 12942:1998/A1:2002 Respiratory protective devices - Power assisted filtering devices incorporating full face masks, half masks or quarter masks - Requirements, testing, marking
EN 12942:1998/A2:2008 Respiratory protective devices - Power assisted filtering devices incorporating full face masks, half masks or quarter masks - Requirements, testing, marking
EN 13274-1:2001 Respiratory protective devices - Methods of test - Part 1: Determination of inward leakage and total inward leakage
EN 13274-2:2001 Respiratory protective devices - Methods of test - Part 2: Practical performance tests
EN 13274-3:2001 Respiratory protective devices - Methods of test - Part 3: Determination of breathing resistance
EN 13274-4:2001 Respiratory protective devices - Methods of test - Part 4: Flame tests
EN 13274-5:2001 Respiratory protective devices - Methods of test - Part 5: Climatic conditions
EN 13274-6:2001 Respiratory protective devices - Methods of test - Part 6: Determination of carbon dioxide content of the inhalation air
EN 13274-7:2008 Respiratory protective devices - Methods of test - Part 7: Determination of particle filter penetration
EN 13274-8:2002 Respiratory protective devices - Methods of test - Part 8: Determination of dolomite dust clogging
EN 13794:2002 Respiratory protective devices - Self-contained closed-circuit breathing apparatus for escape - Requirements, testing, marking
EN 13949:2003 Respiratory equipment - Open-circuit self-contained diving apparatus for use with compressed Nitrox and oxygen - Requirements, testing, marking
EN 14143:2013 Respiratory equipment - Self-contained re-breathing diving apparatus
EN 14387:2004+A1:2008 Respiratory protective devices - Gas filter(s) and combined filter(s) - Requirements, testing, marking
EN 14435:2004 Respiratory protective devices - Self-contained open-circuit compressed air breathing apparatus with half mask designed to be used with positive pressure only - Requirements, testing, marking
EN 14529:2005 Respiratory protective devices - Self-contained open-circuit compressed air breathing apparatus with half mask designed to include a positive pressure lung governed demand valve for escape purposes only
EN 14593-1:2005 Respiratory protective devices - Compressed air line breathing apparatus with demand valve - Part 1: Apparatus with a full face mask - Requirements, testing, marking
EN 14593-2:2005 Respiratory protective devices - Compressed air line breathing apparatus with demand valve - Part 2: Apparatus with a half mask at positive pressure - Requirements, testing, marking
EN 14594:2005 Respiratory protective devices - Continuous flow compressed air line breathing apparatus - Requirements, testing, marking
EN 14594:2005/AC:2005 Respiratory protective devices - Continuous flow compressed air line breathing apparatus - Requirements, testing, marking - missing
EN 15333-1:2008/AC:2009 Respiratory equipment - Open-circuit umbilical supplied compressed gas diving apparatus - Part 1: Demand apparatus
EN 15333-2:2009 Respiratory equipment - Open-circuit umbilical supplied compressed gas diving apparatus - Part 2: Free flow apparatus
or
