Of Invensys is now! Just Schneider Electric's .
PRO / II performs rigorous calculations material and heat balances for a wide range of processes* from the primary separation of oil and gas to the reactive distillation processes.
interfaces:
- HTFS - automates the retrieval of data for streams based PRO / II data and create on their basis of input-file for HTFS;
- HTRI - makes it possible to fully integrate the design of the program and the calculation of shell and tube heat exchangers HTRI XIST;
- Linnhoff-March - material and energy balances of the PRO / II can be transferred to Column SuperTarget software package module for analyzing the energy efficiency of the separation process.
Additional special modules:
- Batch - calculation stirred tank reactor and the batch rectification periodic calculation process can be run separately or as part of PRO / II flowsheet;
- Electrolytes - This module integrates with thermodynamics OLI Systems company electrolytes and pozvolyaetgenerirovat own thermodynamic model of electrolytes* to create their own databases and work with them.
- Polymers - allows to simulate industrial processes involving polymer - by purification of monomers and polymerization reactions to separation and processing. Polymers makes it possible to describe any resin component as a set of fractions having a certain average molecular weight* which allows an accurate modeling of the mixing and separating polymers.
- Profimatics - model company KBC reactors (REFSIM* HTRSIM* FCCSIM) included in the PRO / II program as technological devices. Note that data components and thermophysical properties including recycles convergence is automatically updated in the calculation.
- AMSIM - module for rigorous modeling of cleaning acid gases amine solutions in PRO / II is fully integrated package AMSIM DB Robinson company.
Areas of use:
- Refining (atmospheric column of the primary distillation; block oil heating; column separation coker; main column catalytic *****ing* installation of gas separation; gasoline stabilizer; setting redistillation gasoline; reactor units; cleaning sour water; alkylation in the presence of H2SO4 and HF; vacuum column) .
- Gas Processing (amine purification Fitting cascaded refrigeration* compressor stations* deethanizer and a demethanizer; detandirovaniya installation; gas dehydration; hydrate inhibition; multistage separation* operation platforms cooling cycles Fitting optimization turbodetandirovaniya).
- Petrochemicals (separation of aromatics* separation of fraction C3; manufacture cyclohexane; ethylene plant* obtaining MTBE* naphthalene selection* production of olefins* propylene chlorination).
- Chemistry (synthesis of ammonia* azeotropic and extractive distillation* crystallization* evaporation* dehydration processes* processes of inorganic chemistry (including electrolytes); extraction; phenol rectification plant; solid phase processes).
Schneider Electric SimSci PRO / II v9.3 + =Schneider Electric SimSci PRO / II v9.3 link
645 Mb (. RAR5* incl 3% - info for restoration purpose)
Must be loged on lavteam to see and download
