Thread: IEC Collection 056/150: IEC TC 78-Live Working
    fulllist:
    IEC 60743:2013 Live working - Terminology for tools* devices and equipment
    IEC 60832-1:2010 Live working - Insulating sticks and attachable devices - Part 1: Insulating sticks
    IEC 60832-2:2010 Live working - Insulating sticks and attachable devices - Part 2: Part 2: Attachables devices
    IEC 60855-1:2016 Live working - Insulating foam-filled tubes and solid rods - Part 1: Tubes and rods of a circular cross-section
    IEC 60895:2002 Live working - Conductive clothing for use at nominal voltage up to 800 kV a.c. and +/- 600 kV d.c.
    IEC 60895:2002/COR1:2003 Corrigendum 1 - Live working - Conductive clothing for use at nominal voltage up to 800 kV a.c. and +/- 600 kV d.c.
    IEC 60900:2012 Live working - Hand tools for use up to 1 000 V a.c. and 1 500 V d.c.
    IEC 60903:2014 Live working - Electrical insulating gloves
    IEC 60984:2014 Live working - Electrical insulating sleeves
    IEC 61057:2017 Live working - Insulating aerial devices for mounting on a chassis
    IEC 61111:2009 Live working - Electrical insulating matting
    IEC 61112:2009 Live working - Electrical insulating blankets
    IEC 61219:1993 Live working - Earthing or earthing and short-circuiting equipment using lances as a short-circuiting device - Lance earthing
    IEC 61219:1993/COR1:2000 Corrigendum 1 - Live working - Earthing or earthing and short-circuiting equipment using lances as a short-circuiting device - Lance earthing
    IEC 61229:1993+AMD1:1998+AMD2:2002 CSV Rigid protective covers for live working on a.c. installations
    IEC 61229:1993 Rigid protective covers for live working on a.c. installations
    IEC 61229:1993/COR1:2000 Corrigendum 1 - Rigid protective covers for live working on a.c. installations
    IEC 61229:1993/AMD1:1998 Amendment 1 - Rigid protective covers for live working on a.c. installations
    IEC 61229:1993/AMD2:2002 Amendment 2 - Rigid protective covers for live working on a.c. installations
    IEC 61230:2008 Live working - Portable equipment for earthing or earthing and short-circuiting
    IEC 61235:1993 Live working - Insulating hollow tubes for electrical purposes
    IEC 61235:1993/COR1:1999 Corrigendum 1 - Live working - Insulating hollow tubes for electrical purposes
    IEC 61235:1993/COR2:2000 Corrigendum 2 - Live working - Insulating hollow tubes for electrical purposes
    IEC 61236:2010 Live working - Saddles* stick clamps and their accessories
    IEC 61243-1:2003+AMD1:2009 CSV Live working - Voltage detectors - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61243-1:2003 Live working - Voltage detectors - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61243-1:2003/COR1:2005 Corrigendum 1 - Live working - Voltage detectors - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61243-1:2003/AMD1:2009 Amendment 1 - Live working - Voltage detectors - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61243-2:1995+AMD1:1999+AMD2:2002 CSV Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2:1995+AMD1:1999 CSV Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2:1995 Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2:1995/COR1:1996 Corrigendum 1 - Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2:1995/COR2:1999 Corrigendum 2 - Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2:1995/COR3:2000 Corrigendum 3 - Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2/AMD1:1999 Amendment 1 - Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-2/AMD2:2002 Amendment 2 - Live working - Voltage detectors - Part 2: Resistive type to be used for voltages of 1 kV to 36 kV a.c.
    IEC 61243-3:2014 Live working - Voltage detectors - Part 3: Two-pole low-voltage type
    IEC 61243-3:2014/COR1:2015 Corrigendum 1 - Live working - Voltage detectors - Part 3: Two-pole low-voltage type
    IEC 61243-3:2014/COR2:2015 Corrigendum 2 - Live working - Voltage detectors - Part 3: Two-pole low-voltage type
    IEC 61243-5:1997 Live working - Voltage detectors - Part 5: Voltage detecting systems (VDS)
    IEC TR 61243-6:2017 Live working - Voltage detectors - Part 6: Guidelines on non-contact voltage detectors (NCVD) for use at nominal voltages above 1 kV AC
    IEC 61318:2007 Live working - Conformity assessment applicable to tools* devices and equipment
    IEC TR 61328:2017 Live working - Guidelines for the installation of transmission and distribution line conductors and earth wires - Stringing equipment and accessory items
    IEC 61472:2013 Live working - Minimum approach distances for a.c. systems in the voltage range 72*5 kV to 800 kV - A method of calculation
    IEC 61472:2013/COR1:2015 Corrigendum 1 - Live working - Minimum approach distances for a.c. systems in the voltage range 72*5 kV to 800 kV - A method of calculation
    IEC 61477:2009 Live working - Minimum requirements for the utilization of tools* devices and equipment
    IEC 61477:2009/COR1:2009 Corrigendum 1 - Live working - Minimum requirements for the utilization of tools* devices and equipment
    IEC 61478:2001+AMD1:2003 CSV Live working - Ladders of insulating material
    IEC 61478:2001 Live working - Ladders of insulating material
    IEC 61478:2001/AMD1:2003 Amendment 1 - Live working - Ladders of insulating material
    IEC 61479:2001+AMD1:2002 CSV Live working - Flexible conductor covers (line hoses) of insulating material
    IEC 61479:2001 Live working - Flexible conductor covers (line hoses) of insulating material
    IEC 61479:2001/AMD1:2002 Amendment 1 - Live working - Flexible conductor covers (line hoses) of insulating material
    IEC 61481-1:2014 Live working - Phase comparators - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61481-1:2014/COR1:2015 Corrigendum 1 - Live working - Phase comparators - Part 1: Capacitive type to be used for voltages exceeding 1 kV a.c.
    IEC 61481-2:2014 Live working - Phase comparators - Part 2: Resistive type to be used for voltages from 1kV to 36 kV a.c.
    IEC 61482-1-1:2009 Live working - Protective clothing against the thermal hazards of an electric arc - Part 1-1: Test methods - Method 1: Determination of the arc rating (ATPV or E<sub>BT50</sub>) of flame resistant materials for clothing
    IEC 61482-1-2:2014 Live working - Protective clothing against the thermal hazards of an electric arc - Part 1-2: Test methods - Method 2: Determination of arc protection class of material and clothing by using a constrained and directed arc (box test)
    IEC 61482-2:2009 Live working - Protective clothing against the thermal hazards of an electric arc - Part 2: Requirements
    IEC 62192:2009 Live working - Insulating ropes
    IEC 62193:2003 Live working - Telescopic sticks and telescopic measuring sticks
    IEC 62237:2003 Live working - Insulating hoses with fittings for use with hydraulic tools and equipment
    IEC TR 62263:2005 Live working - Guidelines for the installation and maintenance of optical fibre cables on overhead power lines
    missing:
    Re: IEC Collection 056/150: IEC TC 78-Live Working
    full list 23.11.2017:
    the missing:
  1. IEC 60903 2014 Live working - Electrical insulating gloves
    By John Keys in forum Safety And Environment
    Last Post: 02-28-2017, 06:36 PM
  2. Live GOM Oil Spill Camera
    By mobek in forum Safety And Environment
    Last Post: 07-14-2010, 11:51 PM
  3. How to Live on 24 Hours a Day
    By adiiliuta in forum Self Improvement
    Last Post: 11-14-2009, 07:19 PM
