Thread: drainage area calculation?
  1. drainage area calculation?
    we are going to drill a new vertical well wich is spaced about 600 m about the existing producer (producing at 9m3/hr with cummulative production of 260000 m3)* we have only DST data for this well (no pressure data after 3years of production)* the kh was about 160mdm (vertical homogeneous acting radial flow).we are dealing with tight reservoir* some drilled wells in this area has kh smaller than 30mdm and others greater than 100 mdm(nearest producer kh=160mdm)
    I found my scaping too small*
    I need hand calculation to confirm if I will interfere with the existing producer then I will drop my reservoir pressure below Pb quickly
    please any precious help
  2. Re: drainage area calculation?
    I used a simple volumetric calculation using the following equation: : OOIP=Np=A*h*NTG*(1-Sw)/Bo=(pi*r^2)*h*NTG*(1-Sw)/Bo and I got the average current drainage radius (r)* I tryed also to plot 1/q vs Np/q* 1/the slope is the EUR of the well then i use the same volumetric equation to get the drainage radius.
    Am I right ? Is there any other method to get the drainage area?
  4. Re: drainage area calculation?
    I am eagerly waiting for your replies.
  1. well Drainage area
    By bayan in forum Reservoir
    Last Post: 04-29-2017, 11:28 PM
  2. Determination of average drainage area pressure
    By pet_spec in forum Reservoir
    Last Post: 04-18-2013, 10:08 PM
  3. Article: Estimate drainage Area for vertical well
    By mohamed_B in forum Home Articles
    Last Post: 01-10-2012, 09:07 PM
  4. Estimate drainage Area for vertical well
    By mohamed_B in forum Reservoir
    Last Post: 12-28-2011, 05:26 PM
  5. drainage area and well spacing
    By sharpjiy in forum Reservoir
    Last Post: 03-09-2011, 09:47 PM
