Could we share here libraries devices files for etap.
files *.lib
files *.lib
How to include components into the ETAP Library
1. Go to file menu; then Log off at active proyect
2. Close the active proyect; select yes option
3. save active proyect
4. confirm save option
5. Log on with your user
6. Use Access level: Librarian Option; then select ok
7. At active proyect screen; go to Library menu; then copy/merge option
8. Look for the component library file *.lib ext
9. click on the arrow that is between both file locations; arrow show that library file below is going to be imported to the main library file; etaplib###.lib default library file. Then click on Ok.
10. Next screen will show the components to be added to main library file; then click on ok
11. Components will be added
12. Components will apear at library now
Excelente ayuda, muchas gracias.
Great tutorial* please add more tutorials.
Another library tutorioal for etap:[link Point to another website Only the registered members can access]
Registering LV MCCB to the Library (With Thermal-Magnetic Trip Unit)
ETAP LIBRARY FILE: ->
ETAP Lib_2.0(LSIS_Product).lib ; 210196KB (205.27MB) -> from[link Point to another website Only the registered members can access]
another libraries for etap: fuses; cb; relays and reclosers and more.
pass:
0
to install it on ETAP must do the procedure on;[link Point to another website Only the registered members can access]
4shared accounts have too problems with copyrights and are banned soon with that content*
anybody here have cable library in etap 16? .-.
