We have medium pressure steam supply to a plant with two parallel orifice flow meters installed side by side* say FT-101 and FT-102. Both lines are insulated upto impulse tubes.
Usually 101 is kept in line and shows flow around 40-45 T/H. Recently we have replaced orifice of FT-102* removed its insulation* and took it in line. For seven days* the meter shows correct readings* reconciled by other meters. Yesterday* the insulation was replaced. Immediately* FT-102 starts showing reduction in flow readings in the tune of almost 10%. As we again remove the insulation* FT-102 starts showing correct readings.
We fail to understand the relation between insulation and flow reading. Could you please provide any feasible cause for this?
