Results 1 to 6 of 6
Thread: [help] heat rate correction factor
  1. [help] heat rate correction factor
    I found many heat rate correction factor in tables according to attach file. The heat rate changing by ambient temperature and condenser cooling water in steam power plant, super critical parameters. Can some one help me how to calculate that, i need standard or equations, Thanks very much!
    Sorry im not good at english
    Re: [help] heat rate correction factor
    Please, explain best what is your problem.
    But for derating of performamce of electrical devices due to temperature, you must see the standard iec 60085
    bye
    what are you trying to do? show us some equations or give a better explanation
  5. Re: [help] heat rate correction factor
    Thanks for answer. I want to calculating effect of ambient temperature and condenser cooling water on power plant perfomance (or heat rate of cycle = heat input/Electric out put) and factor ratio in thermal power plant. I have a picture relationship between temperature and heat rate factor ratio reference to ambient temperature and condenser cooling water temperature, but i dont know the standard/code to calculating or equation for this relationship
    Attach
    HI:
    therea are no specific curves or equations to solve this problem, the method to calculate is as follows
    First step is to have correction curves vs temperature for condenser and cooling tower ( if you have) and then calculate STexhaust pressure and power output, you must repeat this for each ambient temp. to be considered
    Some specific programs for Thermal Power plants such as Thermoflow suite or Gate Cycle can aid to solver this easier
  8. Re: [help] heat rate correction factor
    thank you
  1. Propylene Cargo Measurement (Correction Factor Standard)
    By jordanlutherbasawil in forum Petroleum Refining
    Last Post: 07-09-2014, 11:05 AM
  2. static refraction correction
    By tdb in forum Geology & Exploration
    Last Post: 07-10-2012, 12:44 PM
  3. Calculating compressibility factor (z-factor)
    By petro_student in forum Oil And Gas Production
    Last Post: 10-04-2009, 09:02 AM
