Thread: Prosper problem
  1. Prosper problem
    Hi, i have a problem with the simulation of a well in the prosper software, in the analysis summary(system section), im trying to make an analysis of the actual conditions of a well. When i try to simulate the conditions in the outlet (pipeline) the VLP curve remain the same value for all the rate points. The IPR curve also shows a strange behavior with all the vertical lift correlations. I attached a picture to better explain the problem.
    I hope some of you can help me.
    DAIH
  2. Re: Prosper problem
    Hello DAIH
    You should change "Solution node"
    Re: Prosper problem
    Change the solution node to the bottom node. Right now the solution node is set to the top node which has a fixed pressure of 26.9 Kg/cm2. That's why the VLP is a flat line.
  1. Prosper
    By roberdani12 in forum Oil And Gas Production
    Last Post: 12-05-2014, 11:32 AM
  2. Replies: 9
    Last Post: 05-24-2011, 08:08 AM
